"Reboot and select proper media or insert bootable device,and press a key."
NiroshB
My brother brought a laptop from PCspecialist last dec,
Chassis & Display Octane Series: 15.6" Matte Full HD IPS LED Widescreen (1920x1080)
Processor (CPU) Intel® Core™i7 Quad Core Processor i7-6700k (4.0GHz) 8MB Cache
Memory (RAM) 16GB HyperX IMPACT 2133MHz SODIMM DDR4 (2 x 8GB)
Graphics Card NVIDIA® GeForce® GTX 1060 - 6.0GB GDDR5 Video RAM - DirectX® 12.1, G-SYNC
1st Hard Disk NOT REQUIRED
M.2 SSD Drive 512GB SAMSUNG SM961 M.2, PCIe NVMe (up to 3200MB/R, 1700MB/W)
Memory Card Reader Integrated 6 in 1 Card Reader (SD /Mini SD/ SDHC / SDXC / MMC / RSMMC)
Power Supply 1 x 230W AC Adaptor
Power Cable 2 x 1 Metre UK Power Cable (Kettle Lead)
with windows 10 OS.
affter using 06 months,came up an error when boot up the laptop ,"Reboot and select proper media or insert bootable device,and press a key." so i went to bios and in the boot device section it shows UEFI IP4 Killer PCIE Network controller / UEFI IP6 Killer PCIE Network controller
and i set up bios to restore and restart few times,and ttry to reinstall Fresh windows copy ,using a flash drive and on the menu it didn't appears SSD Drive,after few restart it suddenly appears the SSD Drive so,what i did ,fully formated the SSD Drive and install fresh copy,and shut down..
Today when i switched on the laptop the same error ; "Reboot and select proper media or insert bootable device,and press a key." ..apears again.
any clue what's went wrong here with my laptop
Rakk
The Awesome
Well I'm sure it could be a few things and I'll let more experienced people answer, but one thing I will say if there's anything stored on the SSD that you need to keep then back it up somewhere else if you manage to get it working again (this advice comes from someone who's just had an SSD die on them ... Rakk is still somewhat annoyed lol) - though if you've recently just done a fresh install you may not have too much that isn't stored elsewhere.
That looks like a serious SSD error to me. The clues are the fact that the SSD doesn't show up in the list of boot devices in the BIOS and neither does it show up in the first 'Where do you want to install Windows' dialog.
Your second ''Where do you want to install Windows' dialog does show the drive however so when did you see this? Is this when you managed to reinstall Windows?
If you're saying that the SSD drive sometimes shows up and sometimes doesn't I'd be tempted to remove it and reinsert it, it's an M.2 drive so you'll have to remove a locking screw first. Just make sure there is no dirt or the like on the connectors.
If the drive shows up in the 'Where do you want to install Windows' dialog afterwards delete ALL partitions on the SSD (you will loose all user data however) and then allocate one partition the size of the whole SSD. Windows will automatically recreate the five GPT partitions you need for UEFI boot. You install Windows into the largest of these partitions (normally partition 3).
If that doesn't help then you probably have a dead or dying SSD drive I'm afraid. Since you only bought it last December it will be under warranty so you should then call PCS.
NiroshB
yes..first when i got the errors,i was really scared,so after few errorss ocured,i thought it might be Battery issue,and plugged it off,and used the power code,initially after i did that,it helps and boot from SSD Drive,but after shut it down,and switched it on in couple of hrs,error occurs in,but after few tries restarting,SSD Drive shows up,so what i did delete ALL partitions on the SSD allocate one partition the size of the whole SSD and install Windows into the largest partition,hence after i shut it down and switched it on in couple of hrs.same error.
so what ur suggentions.. pls.
I think you have a faulty SSD. I would suggest you phone PCS (don't email them, phone them). Your laptop may have to be sent back however.....
NiroshB
hi,
As i mentioned before ,i thought i should try with another new hard disk ,and i brought a 1 TB,so after that few restart clickes,i can able to boot,after that delete all partitions ,this time inste the 1st Hard Disk and partitioned it and install fresh windows 10 OS .it's all went good until i switch on the laptop today,after 8 hrs.same error showing again.
So is it error with laptop
hi,
Nice work, that's a really good test!
In that case I would call PCS and arrange to have the laptop RMA'd. When you send it back include detailed documentation describing exactly how it fails, under what conditions it fails (ie. what you have to do to get it to fail) and a description of the fault-finding you have done (including trying a new HDD). The more detailed you can make your problem description to PCS the more likely it is that they'll be able to reproduce the fault and then diagnose it.
NiroshB
Yes,thanks..I have noticed that,after shutdown the laptop for around few hrs,and when i switched on the error occurs,and after few restart it will boot normal.that's really confusing
Yes it is, which is why it's essential that you document how it fails in as much detail as you can manage so that PCS can try to reproduce it on their workbench. They can't fix what they don't see...
NiroshB
Today ,after few days ,back it'ss all ready to ship the Laptop to PCS.( Cuz,i am living in Sri Lanka),i switched on the lap,and same error : Reboot-and-select-proper-media-or-insert-bootable-device-and-press-a-key,
so,before i sennt it back,i unplugged the battery and plugged it again,and switch on the laptop,and it's boot from OS.
This is total confusing me,any suggestions
I think it needs to go back to PCS. You've already proved it's not the drive itself and there really isn't anything else you can reasonably do I don't think.
NiroshB
Hello,
last year I sent my Octane Series: 15.6 laptop to PCS. due to the error : "Reboot and select proper media or insert bootable device,and press a key".After they fixed da error and sent it back,now I am ussing it for 08 months,guess what it's showing the same error.again.
Hello,
If you go into the bios, does it register your boot drive? If so, manually change the boot options to list that drive first. If not, you’ve got a failed drive or it needs reseating.
Edit, just read over the beginning of this thread, that’s gotta be more than bad luck! Have you monitored temperatures on the laptop whilst you’ve used it?
NiroshB
now, I've shut down the lap for a couple of days, and switched on same error, but I found every time,when I restart it again,it will boot.is this something wrong with bios or Cmos battery
I would definitely log it with PCS. CMOS wouldn't contribute to a drive not being recognised on a modern board i don't think.
