Recoil 16" - Control Keys not Working
Tb6sra
I have bought another machine from PCS I am having a very weird problem the Ctrl B button isn't working but Cntl functions are working on other shortcuts Cntl C V . I have seen other people having the same issues with the Recoil 16 unit.
I have tired uninstalling the Drivers and reinstalling them. switching the computer on and off. tried many of the solutions on the internet have suggested is this windows 11 issue or a PCS issue?
Any assistance would be great as it is annoying not being able to use shortcuts on the keyboard.
Chassis & Display
Recoil Series: 16" Matte QHD 240Hz sRGB 100% LED Widescreen (2560x1600)
Intel® Core™ i9 24 Core Processor 13900HX (5.4GHz Turbo)
64GB Corsair 4800MHz SODIMM DDR5 (2 x 32GB)
NVIDIA® GeForce® RTX 4080 - 12.0GB GDDR6 Video RAM - DirectX® 12.1
2TB SAMSUNG 990 PRO M.2, PCIe 4.0 NVMe (up to 7450MB/R, 6900MB/W)
2nd M.2 SSD Drive
Windows 11 professional
Did you order with windows as you haven’t posted your full specs?
What are you trying to action ctl b within? Can you try it in something like a local word document?
What language keyboard setting are you using?
Ctl B is a standard windows shortcut, it’s not related to drivers or anything. If your B key is working ok and ctl is working fine in other uses then there’s nothing wrong with the keyboard.
Likely keyboard language is set to something other than English / American or the web page or something you’re entering it in isn’t registering it or doesn’t support it.
