Modern laptops require the battery in place even if they're plugged into the mains as they still use some power from the battery anyway under load.Patiently awaiting delivery of my 17” Recoil. I know the battery is built in but is there any worth in removing it to avoid it being damaged as I intend to use it mainly plugged in or is it required to stay in place ?
No worries. Best advice I can suggest, when you're not using it, don't leave the power live (even if the laptop is fully switched off), as that can cause trickle charging which can degrade the laptop.Many thanks.
