Hi all,
I have recently received my brand spanking new laptop, which so far has been great. However whilst I have somewhat of a technical brain (I am an engineer) I am not super clued up on electronics and IT.
I've noted that whilst gaming (Wasteland 3, all settings to max), if I set the profile on my laptop to 'office mode' the CPU and GPU temperatures will remain around 60 degrees C and the laptop will run quietly. I've then set the laptop to 'gaming mode' and the fans will kick up significantly, and the GPU and CPU temps will shoot up to 70-80 degrees C.
Can someone explain why this is? Does 'office mode' reduce the wattage of the components automatically? I tried to see the difference in the 'SPC Settings' and couldn't see any difference between the two modes.
Additionally, does anyone with the same chassis/setup have any tips/recommendations to optimize the system? Any good resources for me to read up on it?
Cheers!
For reference, this is what I'm using:
Cheers!
Chassis & Display | Recoil Series: 15.6" Matte QHD 165Hz sRGB 100% LED Widescreen (2560x1440) |
Processor (CPU) | AMD Ryzen™ 9 Eight Core Processor 5900HX (3.3GHz, 4.6GHz Turbo) |
Memory (RAM) | 16GB Corsair 3200MHz SODIMM DDR4 (2 x 8GB) |
Graphics Card | NVIDIA® GeForce® RTX 3070 - 8.0GB GDDR6 Video RAM - DirectX® 12.1 |
1st M.2 SSD Drive | 500GB SAMSUNG 970 EVO PLUS M.2, PCIe NVMe (up to 3500MB/R, 3200MB/W) |
2nd M.2 SSD Drive | 500GB SAMSUNG 970 EVO PLUS M.2, PCIe NVMe (up to 3500MB/R, 3200MB/W) |
Memory Card Reader | Integrated SD Memory Card Reader |
AC Adaptor | 1 x 230W AC Adaptor |
Power Cable | 1 x 1 Metre UK Power Cable (Kettle Lead) |
Battery | Recoil Series Integrated 94WH Lithium Ion Battery |
Thermal Paste | ARCTIC MX-4 EXTREME THERMAL CONDUCTIVITY COMPOUND |
Sound Card | 2 Channel High Definition Audio + MIC/Headphone Jack |
Bluetooth & Wireless | GIGABIT LAN & WIRELESS INTEL® Wi-Fi 6E AX210 (2.4 Gbps) + BT 5.0 |
USB/Thunderbolt Options | 1 x USB 3.2 PORT (Type C) + 3 x USB 3.2 PORTS |
Keyboard Language | PER-KEY RGB BACKLIT UK MECHANICAL KEYBOARD |
Operating System | Windows 10 Home 64 Bit |
