Red CPU light on Motherboard
Hunkydunky
Hi all :)
I've only had my new PC several weeks and it has been working flawlessly until now!
Just yesterday I attempted to boot my PC - All RGB lights came on (Nothing seems to be missing) however the PC does not even get to the boot screen - There is a red flashing light labelled 'CPU' on my motherboard. The AIO cooler I have is all lit up red and once I attempted to re-boot to see if it'd fix itself, the AIO screen has a constant caution sign showing whereas before there was nothing when powered off.
On closer inspection of the CPU light on the motherboard, it may be hard to see but it seems to have '301' written underneath. Not entirely sure if it's related but attaching photo just in case.
Attaching photos and specs:
Intel® Core™ i9 24-Core Processor i9-13900K (3.0GHz) 36MB Cache
ASUS® ROG STRIX Z790-F GAMING WIFI (DDR5, LGA1700, USB 3.2, PCIe 5.0) - ARGB Ready
32GB Corsair DOMINATOR PLATINUM RGB DDR5 6000MHz (2 x 16GB)
24GB NVIDIA GEFORCE RTX 4090 - HDMI, DP
Graphics Card Support Bracket
PCS ARGB GRAPHICS CARD SUPPORT BRACKET
2TB SEAGATE FIRECUDA 530 GEN 4 PCIe NVMe (up to 7300MB/R, 6900MB/W)
CORSAIR iCUE H150i ELITE LCD XT RGB CPU Cooler
Extra Case Fans
Welcome Book
Logo Branding
PCSpecialist Logo
B4zookaw
Puzzling. If the CPU failed, I’d still expect the AIO to function, and not show signs of error. And similar if the AIO failed the system should still boot, but might eventually shutdown if the CPU hit max temp.
Any messages displayed in BIOS on boot?
If the AIO failed, it might depend how the system views the failure...if the system decides that there's no functional cooler, then that might possibly be why....when I've tried doing troubleshooting in the past and disconnected the CPU fan, then the system point blank refuses to boot
That should still boot to a BIOS warning page.
It's possible the OP has a screen that isn't compatible with BIOS output which is why it's not displaying.
Hunkydunky
That's a good shout - I've never had issues with my monitor showing BIOS on my previous PC but when I get home after work, i'll chuck a different monitor on to see if that yields any further results, then shout with an update back here :)
B4zookaw
Might also be worth taking the side off the case and checking the cooler connection on the motherboard...it's possible it came loose during transit...sometimes things can come loose but take a while to cause an issue. I think it plugs direct in to the motherboard with your configuration:
No, Corsair AIO is all controlled via controller that connects to USB header. It connects to CPU FAN header to report a speed to allow it to boot as others have mentioned, but the fan headers don’t control the pump or fans in any way.
Hunkydunky
Howdy gents, thanks a million for all of the replies so far :)
Update: Unfortunately BIOS does not show even on another monitor using Displayport and including a third monitor connected by HDMI - No output whatsoever.
I've just noticed that my keyboard and mouse don't get any power from the PC at all either from any of the USB ports on the motherboard.
Live update to the update: I attempted to plug in my phone using the USB C port while the PC was powered on to test if there was any power output whatsoever and as soon as I plugged in the phone, it took several seconds for the phone to charge and then... the motherboard gave one beep and the entire PC came back to life...?! What is this sorcery?! :ROFLMAO:
I've since restarted the PC several times throughout the day at random just to test to see if charging my phone really did fix the issue and.. it seems to have. Everything is back to normal.
Bizarre.
Anywho, unless it kicks the bucket again, a big thank you to everyone for your time :D
RichLan564
I'm not sure I'd be happy with that. I would call PCS and talk this all through with them. It sounds like there might be a flaky motherboard issue to me......
That was my thought exactly, plugging a phone into a USB-C port isn't going to make a PC more likely to boot, not unless there is something else seriously amiss
