Hi all.
A couple of years ago I purchased a liquid series PC from PC specialist.
I haven't changed the coolant in that time, so I really need to do that, and I'd like to upgrade the graphics card to a 2080 TI. I was all ready to cop out and let PC Specialist do the upgrade for me, but they have limited stock on the new cards so said there might be a delay, so I figure I'm going to try and level up my feeble hardware skills and do this myself (don't laugh).
The thing I'm unsure on is that my current card (a 1080) is liquid cooled. So there's a tube going from my reservoir, to the graphics card waterblock, and then on to the processor. If I remove this card to change it I'll also need to remove the waterblock and I presume add a new tube from the reservoir to the processor (I think I'm not bothered about liquid cooling the new card).
So I think what I need to do is, follow the instructions/YouTube videos for draining the coolant ready to change it, then run a new piece of tube from the reservoir to the processor, before refilling the system with new coolant.
First of all, is this something I should even be attempting myself? I've not done anything with liquid before. How much of a risk is there I'm going to destroy my machine?
Does anyone know which type of tubing I should buy to match the PC Specialist one? From what I've seen it looks like I'd need to cut it myself to size.
Anything else I should beware of?
Thanks all
Thanks all
