Replacement Charger
triviup
My charger has split so the wires are exposed, does anyone know where I could get a replacement that wont cost the earth?
Can you post the full spec from your orders page, while you are there check the spares section for the laptop, charger should be listed in there if it's a pc specialist laptop
