This laptop initially appeared slim and good looking as well as portable and powerful. However slim proved to be flimsy. Warning - the track pad is so sensitive and the chassis so flimsy that the mouse moves the cursor even when you are not touching the pad - just using the keypad!! This is clearly a fault. When I returned mine because of this fault they then charged me for windows 7 as it had been activated on what I thought was going to be my primary laptop. Be careful with pc specialist products - make sure that you are happy with them before activating windows - an expensive mistake I found.
