RTX 3000 Series Stutter Issue
Grendel85
HI Guys,
Anyone else having stutter issues with the 3000 card? While playing games i am getting stutter and lag FPS is nice and high but something is just not running to good.
Just want to see if anyone else is having the same issue and if they have found a fix for it.
I play Warzone most of the time but it is happening in all games.
Citrus_9
Expert
HI Guys,
Would be nice if you read a sticker first ;)
Grendel85
Oh sorry thats my bad,
AMD Ryzen 7 5800X
ASUS® CROSSHAIR VIII HERO
64GB Corsair VENGEANCE RGB PRO DDR4 3200MHz
24GB NVIDIA GEFORCE RTX 3090
500GB SAMSUNG 980 PRO M.2, PCIe NVMe
2TB INTEL® 660p M.2 NVMe PCIe SSD
CORSAIR 1000W RMx SERIES
Windows 10 Home 64 Bit
AMD Ryzen 7 5800X
Can you copy and paste the full spec from your order page please.
Is this a PCS build?
Grendel85
Do you have G-Sync enabled? I was going to suggest that the stutter is because your monitor is a low refresh rate but it's not. G-Sync should solve any lag and stutter (hopefully)
Are your Graphics Drivers up-to-date? When did you last check to see if there were any? NVIDIA are bringing out frequent updates currently to optimise new GPUs for games..sometimes a GPU acting up means an update is available (of course, the question becomes how does the gPU know :eek:)
Hi - I have a 4K LG monitor 144hz and all drivers are currently up to date
I tried the G-Sync and had no luck also uninstalled the drivers and put the previous version on that was horrible was only 90fps on 1440p so just installing the current version again.
Grendel85
CaseCORSAIR CRYSTAL SERIES 680X RGB GAMING CASE
Processor (CPU)AMD Ryzen 7 5800X Eight Core CPU (3.8GHz-4.7GHz/36MB CACHE/AM4)
MotherboardASUS® CROSSHAIR VIII HERO (DDR4, PCIe 4.0, CrossFireX/SLI) - RGB Ready!
Memory (RAM)64GB Corsair VENGEANCE RGB PRO DDR4 3200MHz (4 x 16GB)
Graphics Card10GB NVIDIA GEFORCE RTX 3080 - HDMI, DP
Change to: 24GB NVIDIA GEFORCE RTX 3090 - HDMI, DP
1st Storage DriveNOT REQUIRED
1st M.2 SSD Drive500GB SAMSUNG 980 PRO M.2, PCIe NVMe (up to 6900MB/R, 5000MB/W)
2nd M.2 SSD Drive2TB INTEL® 660p M.2 NVMe PCIe SSD (up to 1800MB/sR | 1800MB/sW)
DVD/BLU-RAY DriveNOT REQUIRED
Power SupplyCORSAIR 1000W RMx SERIES™ MODULAR 80 PLUS® GOLD, ULTRA QUIET
Processor CoolingCorsair H115i RGB PLATINUM Hydro Series High Performance CPU Cooler
Wireless Network CardNONE
Change to: WIRELESS INTEL® Wi-Fi 6 AX200 2,400Mbps/5GHz, 300Mbps/2.4GHz PCI-E CARD + BT 5.0
Operating SystemNO OPERATING SYSTEM REQUIRED
Change to: Windows 10 Home 64 Bit - inc.
Windows Recovery MediaNO RECOVERY MEDIA REQUIRED
Change to: Windows 10 Multi-Language Recovery Image - Unlimited Downloads from Online Account
Change to: BullGuard™ Internet Security - 3 User, 1 Year
Change to: Google Chrome™
Warranty3 Year Standard Warranty (1 Month Collect & Return, 1 Year Parts, 3 Year Labour)
Build TimeStandard Build - Approximately 15 to 17 working days
