RTX 3080 | Page 304 | PCSPECIALIST
RTX 3080
Elliott B
What is your build if you don't mind me asking?
NO RECOVERY MEDIA REQUIRED
That's a monster of a build
ShaMia
Mouth watering build!
I cant see any of your parts listed as out of stock on PCS so not sure why it'll take any longer than others. I'm sure it'll go into building soon. Keep us posted!
I'm on WD 11, but I've noticed one of the case fans I selected is now out of stock, so might remove it from my order. Don't want a fan holding back the build.
Elliott B
I spoke to PCS yesterday and they said if the item was not out of stock when you ordered it then it won't have an effect on build time. They also suggested I would be waiting until next week to enter build.
For reference on my build, I got an OEM thing when I was at Uni which I am still using (4 core 4 thread i5 6400), with whatever rubbish motherboard I have. Admittedly the GTX 970 is good but I have 1 stick of 8 gig ram... After using that for 6 years I felt it was time for an upgrade. My build is 6 years worth of saving and my hope is it's worth it :)
Just on this build mate, if you plan to use wireless I would upgrade that Wifi card to the AX200. The wireless card selected there is ancient single band card, it's pretty terrible. The AX200 also has built in Bluetooth 5.0
Elliott B
I don't really, but having the option is always welcome. I have updated the wifi card :) thank you for the advice
ShaMia
That good to know! appreciate the input. I'll leave my build as is :)
Sounds like your new pc is a HUGE upgrade from the previous, No doubt the 6 years wait will be well worth the wait and a totally new experience
Elliott B
ricards_o
15 days and mine has went in to building. They called me up saying that the 5 fans I picked do not fit in my case and had to be switched with 3, got a refund for the 2 other fans. Currently very satisfied. Cant wait for my rig and first windows machine. Heres the specs if anyones interested:
Case - CORSAIR iCUE 5000X RGB
CPU - AMD Ryzen 9 5900X 12 Core
Motherboard - ASUS® TUF X570-PLUS
RAM - 64GB Corsair VENGEANCE DDR4 3200MHz
GPU - 10GB NVIDIA GEFORCE RTX 3080 - HDMI, DP, LHR
Storage - 2x 2TB CORSAIR MP400 NVMe PCIe M.2 SSD
Power Supply - CORSAIR 850W RMx SERIES
CPU Cooler - Corsair H115i ELITE CAPELLIX RGB
LED Lighting - 2x 50cm ARGB LED Strip
Extra Case Fans - 3x Corsair LL120 RGB LED Fan
Wireless Network Card - INTEL® Wi-Fi 6 AX200
OS - Windows 11 Professional
Elliott B
Im still in build, you may very well have your machine before me :) Best of luck
ricards_o
It has now went to testing on day 16. Called them up because I can only be on the spot on the weekend so I confirmed that my PC will arrive on Saturday this week. The excitement is realll !!!!
