It’s currently a £90 difference for me. Although swapping from the 5800X to 5900X would mean you’d want to upgrade from the TUF X570 to the STRIX X570 for the better VRM’s. The difference of that is another £57 currently. Then there’s CPU cooler but we won’t get into that too😂Is that right?
So the 'Standard'AMD cooler' isn't good enough??It’s currently a £90 difference for me. Although swapping from the 5800X to 5900X would mean you’d want to upgrade from the TUF X570 to the STRIX X570 for the better VRM’s. The difference of that is another £57 currently. Then there’s CPU cooler but we won’t get into that too😂
The 5800X and 5900X actually don't come with coolers from AMD. I imagine PCS probably have a cooler they use. It'd be interesting to see what cooler that is. As long as it pases testing you should be fine as you're planning to swap it as soon as you recieve it.So the 'Standard'AMD cooler' isn't good enough??
Thats what I've ordered for my 5800X since amended to 5900x........as a placeholder in the configurator to get the order processed. I fully intend to immediately swap it out for a 360mm AIO.
