I am experiencing a bit of last minute uncertainty whether I made the right decision going for the pro board instead of the sabertooth.
I do not plan to overclock, but the pc will definitely be put through its paces, and will be used for some heavy duty gaming and benchmarking.
I am not that concerned about wifi as I will be using ethernet.
At some future date, I might add another card and go for an sli set up, and perhaps a sound card as well.
I would really appreciate some advice vis a vis the above before the pc is built
