Hi there,
I bought a Defiance Series laptop from PC Specialist back in March & have noticed two issues with it:
1. The screen dims when I open certain software such as Adobe Photoshop and Illustrator & then brightens up again when I switch to Chrome. I've switched 'Game mode' off and I've not been able to find any other power saving, or power-management settings which might be controlling the screen brightness. The function keys which control brightness don't make a difference. Is there another setting hidden somewhere that can stop this? It's making Photoshop pretty unusable as everything that should appear white is appearing grey!!
2. The computer often doesn't switch on after being asleep overnight. I open the lid, press the power button and the keyboard lights up, but the fans don't start and the screen never shows a log in screen, so I have to do a hard restart each time, which isn't ideal if I already have work open etc...
All drivers are up to date & Windows is also up to date.
Has anyone else had these issues and if so, did you find a fix for them?
Thanks, EK
Thanks, EK
