Secondary laptop - can PCS help me?
sck451
I don't really know my way around PCS's offering of laptops. I have a desktop that does all the heavy lifting, so I don't need anything terribly powerful, but I do want it to feel very snappy essentially when using Office and browsing the internet. I may try to get Parsec working on it so I can remotely use my desktop. I will not be playing any games. I may do a certain amount of coding (Ruby and Node, so all single-threaded stuff).
I'm therefore thinking of something in the £600-700 range. I'd prefer something with a 14" screen and I'd prefer something with a metal chassis to a plastic one.
I'm a little baffled by the options available, so the question: is there something PCS sells that would be appropriate for my requirements?
Helloooo.... sorry for the delay, have slept masses today, just woke up from the obligatory after lunch nap.
Ok, the one I'd personally recommend is the Lafite Pro giving a few reasons:
1/. Aluminium chassis, and very nicely built, quite a solid piece of kit while remaining rather light.
2/. Thunderbolt 4 which comes with some huge long term benefits aside from transfer speeds / external monitors. Also factor in the ability to run an eGPU which for me adds enormous value to a budget chassis.
3/. Reason why the Pro model specifically and not the normal is that the pro allows for normal SODIMMS of RAM whereas the normal Lafite has soldered RAM.
Now to get the specs I would want as a bare minimum, it's coming just over budget, but it's definitely worth it if you can stretch.
Chassis & Display
Lafité Pro Series: 14" Matte Full HD 60 Hz 72% NTSC LED Widescreen (1920x1080)
Intel® Core™ i5 Quad Core Processor i5-1135G7 (2.4GHz, 4.2GHz Turbo)
16GB Corsair 2933MHz SODIMM DDR4 (2 x 8GB)
Integrated Intel® Iris® Xe Graphics
512GB INTEL® 670p M.2 NVMe PCIe SSD (up to 3000MB/sR | 1600MB/sW)
AC Adaptor
1 x 65W AC Adaptor
Battery
Lafité Pro Series Integrated 49WH Lithium Ion Battery
1 x THUNDERBOLT 4 + 1 x USB 3.2 (TYPE C) + 2 x USB 3.2
Keyboard Language
LAFITÉ PRO SERIES SINGLE COLOUR BACKLIT UK KEYBOARD
NO OPERATING SYSTEM REQUIRED
NO RECOVERY MEDIA REQUIRED
Keyboard & Mouse
Webcam
INTEGRATED 1MP HD WEBCAM
Chassis
Clevo NV41MZ (i5-1135G7, FHD 60Hz N7, Blank KB)
Price: £724.00 including VAT and Delivery
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/lafite-pro-II-14/6XwST6Yzcb/
sck451
That's awesome: many thanks. Will add that to my list of options! I had actually been thinking of running Linux (I ran Kubuntu for about a decade) -- is the driver support decent, do you know? (If I can bear to give up OneDrive...)
From what I understand the Clevo chassis rarely have any issues, it's usually the TongFangs that can be a little more challenging to work around, but I'm fairly sure there's been a recent mention of someone installing linux without any issues on the Lafite, I'll just see if I can dig it out
I knew I'd seen one, this is with Debian, not sure how that differs from other Distros:
And in case you need it, there's a GitHub repo for a project called Tuxedo Keyboard to run illuminated keyboards in Linux:
Just further, on older models but gives workarounds which may still be relevant:
FerrariVie
Super Star
I did run Linux Pop!OS a few months ago on my Clevo and didn't have any driver issues. I used Tuxedo's keyboard drivers and it actually works a lot better than Window's version of Clevo Control Center for Keyboard LED (imo). However, what bothered me the most was the CPU and fan controls. The only one I could find was again Tuxedo's copy of control center, but they're not great as found the profiles either too fan noisy or too CPU hot.
For sure there are ways to control CPU and fans using the terminal, but that is not great usability-wise... Imagine needing to create a lot of config files for each profile that you want to use, then save them all on the desktop and run when needed. Too much work for me so came back to windows only, but it is something that is manageable if you're willing to learn how to do it.
EDIT: Regarding the build, within that price range I totally agree with @SpyderTracks suggestion (as usual :))
