Don't worry about formatting the drive pcs do that for you, and cm690 is a good all round case, but I'd stick with the haf x if it's in your budget, it's bigger which means there's more room to move around in, if your constantly adding things to it and the airflow is excellent keeping it cool and it really quiet x
Does PCS buy their cases directly from coolermaster, antec etc....
Does that mean they will have the coolermaster fans inside, or does PCS use their own.
Also, from the spec I posted, my first drive will be a 60GB SSD. This is for the OS. But Its also to store the programs required to go on youtube, the internet etc...
Can anyone tell me if I should have no problems fitting in all these downloads, including the drivers for all the components aswell.
I noticed, if it will still be there, I will get a NFS world starter pack or something. Does that need to come already on the PC?
