Hi, I bought my custom desktop PC from PCSPECIALIST back in December 2012.
Here's my specs (from the invoice):
Case: COOLERMASTER HAF 922 MID TOWER GAMING CASE
Overclocked CPU: Overclocked Intel® Core™i7-3770k Quad Core (3.50GHz @ max 4.60GHz)
Motherboard: ASUS® P8Z77-V PRO/THUNDERBOLT: PCI-E 3.0 READY,WIFI, SLI, X-FIRE
Memory (RAM): 16GB KINGSTON HYPERX GENESIS DUAL-DDR3 2133MHz X.M.P (4 x 4GB KIT)
Graphics Card: 2GB NVIDIA GEFORCE GTX 680 - 2 DVI, HDMI, DP
Memory - 1st Hard Disk: 480GB INTEL® 520 SERIES SSD, SATA 6 Gb/s (upto 550MB/sR | 520MB/sW)
2nd Hard Disk: 2TB WD CAVIAR BLACK WD2002FAEX, SATA 6 Gb/s, 64MB CACHE (7200rpm)
1st DVD/BLU-RAY Drive: 12x BLU-RAY RE-WRITER DRIVE, 16x DVD ±R/±RW
Memory Card Reader: INTERNAL 52 IN 1 CARD READER (XD, MS, CF, SD, etc) + 1 x USB 2.0 PORT
Power Supply: CORSAIR 850W PRO SERIES™ HX850-80 PLUS® GOLD MODULAR
Processor Cooling: Corsair H100 Hydro Series High Performance CPU Cooler
Thermal Paste: ARCTIC MX-4 EXTREME THERMAL CONDUCTIVITY COMPOUND
Sound Card: ASUS Xonar DS
Network Facilities: 10/100/1000 GIGABIT LAN PORT - AS STANDARD ON ALL PCs
USB Options: 6 x USB 2.0 PORTS @ BACK PANEL (MIN 2 FRONT PORTS) AS STANDARD
Operating System: Windows 7 (64-bit)
Warranty: 3 Year Gold Warranty (2 Year Collect & Return, 2 Year Parts, 3 Year
Labour)
Over the past few days I experienced a few occasions where the sound from the speakers would basically go into a recurring error. The speakers would be working fine, and then (usually when I turned on some new sound) they would emit a very annoying and repetitive series of clicking tones (kind a mixture of high and low pitches and very loud). This happened probably twice over the last 3 or 4 days and I had to completely turn the computer off to get the noise to stop (well, turning off the speakers also works, but when you turn them back on the sound is still there). No other sounds would be emitted from the system while that clicking was being made, and I couldn't stop if, except by turning the whole thing off. The first two times, the sound system returned to normal after I restarted the PC.
However, yesterday the same annoying clicking sound took over the sound system again and this time, when I restarted the PC, I couldn't get it to produce any sound. I've been messing around with it today, and all that I can get to come out of the speakers is that annoying sound occasionally (otherwise silence).
When the failure happened yesterday I noticed that the little "Xonar DS Audio Center" start-bar icon was no longer there when I restarted. This icon is always usually there and I use it all the time to adjust volume levels and switch from speakers to headphones and things like that. I went into Control Panel and found the Xonar DS Audio Center program there, but when I click on it, nothing happens (like the button is just dead). I think the Xonar DS Audio Center essentially controls the audio system for the PC and I can no longer access it at all.
Also yesterday, when I restarted after the error (for the second or third time), I got a message saying that the Sound Card wasn't plugged in (or something similar to that). I tried downloading the Xonar DS Audio Center software from the manufacturer's website, but during the installation process it said it couldn't find the Sound Card and thus couldn't install.
I've opened up my PC case and had a quick look inside, and the Sound Card is sitting there and appears to be plugged in. I'm wondering now if I should disconnect it entirely and then reconnect it? (like maybe it's a loose connection issue?). Other than that, I'm not sure what to do. Do you guys think this could be a software problem?, or is it a hardware problem with the Sound Card itself?
Thanks.
Labour)
Thanks.
