Sound issues on Recoil 17, no sound and crackling / high pitch
agrmn
Hey folks.
Recently got the Recoil 17 and installed Pop!_OS 22.04 LTS. However, I'm getting some really odd sounds coming out of the laptop.
Sound doesn't really work, and it's difficult to explain but from time to time, there's a high-pitch sound coming out of the laptop, almost like an alien beep-boop kind-of-thing, even when there's jack headphones plugged in, it's coming out of the laptop, which makes me think it might be a hardware issue. I'm also finding some random crackling which I'm yet to determine if it could be software. I haven't used Windows too much but will try in the coming days.
Has anyone found any similar issues?
Hey folks.
It's difficult to explain but from time to time, there's a high-pitch sound coming out of the laptop, almost like an alien beep-boop kind-of-thing, even when there's jack headphones plugged in, it's coming out of the laptop, which makes me think it might be a hardware issue. I'm also finding some random crackling which I'm yet to determine if it could be software. I haven't used Windows too much but will try in the coming days.
Hiya, is this a pcspecialist device, can you post your full specs from the order page?
agrmn
It is, Recoil 17.
Chassis & Display
Recoil Series: 17" Matte QHD 240Hz sRGB 100% LED Widescreen (2560x1600)
Intel® Core™ i9 24 Core Processor 13900HX (5.4GHz Turbo)
64GB Corsair 4800MHz SODIMM DDR5 (2 x 32GB)
NVIDIA® GeForce® RTX 4080 - 12.0GB GDDR6 Video RAM - DirectX® 12.1
2TB SAMSUNG 990 PRO M.2, PCIe 4.0 NVMe (up to 7450MB/R, 6900MB/W)
AC Adaptor
1 x 330W AC Adaptor
2 x 1.5 Metre UK Power Cable (Kettle Lead)
Battery
Recoil Series Integrated 99WH Lithium Ion Battery
LIQUID METAL PERFORMANCE COOLING
Nahimic by SteelSeries 2 Channel HD Audio
GIGABIT LAN & WIRELESS INTEL® Wi-Fi 6E AX211 (2.4 Gbps) + BT 5.3
1 x THUNDERBOLT 4 PORT + 3 x USB 3.2 PORTS
Keyboard Language
RECOIL 17 SERIES RGB BACKLIT US INTERNATIONAL KEYBOARD
NO OPERATING SYSTEM REQUIRED
US International/USA - US English Language
NO RECOVERY MEDIA REQUIRED
Firefox™
Keyboard & Mouse
Webcam
INTEGRATED 1MP HD WEBCAM
It is, Recoil 17.
Chassis & Display
AC Adaptor
1 x 330W AC Adaptor
Battery
Keyboard Language
Firefox™
Keyboard & Mouse
Webcam
And what driver are you using for audio?
agrmn
Haven't installed anything specific, but this is what lspci shows:
~ ❯ lspci -v | grep -A6 Audio
00:1f.3 Audio device: Intel Corporation Device 7a50 (rev 11) (prog-if 80)
DeviceName: Onboard - Sound
Subsystem: Tongfang Hongkong Limited Device 1252
Flags: bus master, fast devsel, latency 32, IRQ 186, IOMMU group 13
Memory at 6434140000 (64-bit, non-prefetchable) [size=16K]
Memory at 6434000000 (64-bit, non-prefetchable) [size=1M]
Capabilities: <access denied>
01:00.1 Audio device: NVIDIA Corporation Device 22bc (rev a1)
Subsystem: Tongfang Hongkong Limited Device 126c
Flags: bus master, fast devsel, latency 0, IRQ 17, IOMMU group 14
Memory at 84080000 (32-bit, non-prefetchable) [size=16K]
Kernel driver in use: snd_hda_intel
Kernel modules: snd_hda_intel
agrmn
Yes, it's using the incorrect driver so won't work, you need to install the realtek drivers.
Not in this case. It should be built-in into the kernel, which I'm running 6.2.6-76060206-generic. Seems like it could be something to do with pipewire. Have you, or anyone else, heard the noise that I demonstrated? I'm open to trying some other distro if it's discarded it's hardware.
It's not an Intel soundcard though, Intel drivers are t going to work, you need to switch them to realtek
If you install windows you'll see it's a realtek driver applied. The Intel isn't going to work
agrmn
Appreciate the response but this isn't a very actionable comment. I've found someone which might be running into a similar issue, however there's no mention of the high pitch issues I've found:
PopOS is based on Ubuntu, the reporter has a XMG PRO (E23) which by the looks of it is the same chassis as the Recoil 17. Looks like no coincidence. Could anyone from PCS chime in perhaps?
That's a different issue, that's no sound at all.
It won't work on an Intel driver, plain and simple. If you can't install a realtek driver through POPOS, you'll need a different distribution.
Or test the audio in windows
But PCS explicitly state they don't support Linux.
agrmn
I also have no sound, I've modified the main message to make that clearer. When trying to enable or use audio is when I get those weird sound artifacts. I think it could be the same issue.
Windows is fine so far.
It's a driver issue, plain and simple. If you can't install specific drivers in POPOS then you'd need a different distribution.
Intel drivers aren't gonna work
Mnemonic
Hey folks.
You could try installing https://www.sofproject.org/ - not sure how to do this on PopOS, should be easy enough to find out though.
LukeF
Hey folks.
I am having the exact same issue with sound on Debian 12 Bookworm with my PC Specialist Recoil 16. The sound works fine in Windows, but I get the same crazy high-pitch squeals and pops in Debian. Did you manage to find a solution?
Did you try the above suggestion?
LukeF
I tried to install the Realtek driver, however, for Linux, you need to compile it yourself. Unfortunately, the Linux driver only supports Linux kernel version 3.18 or earlier. The current kernel version for Debian Bookworm is 6.1. I tried to compile it anyway, but, as suspected, it was not possible.
agrmn
I returned the laptop (found some incompetency on PCS' end here) and bought from another vendor.
No issues on Arch/Fedora and most importantly I'm not treated as if I don't understand a linux system. Good luck!
