To be honest with you, I have a core I5 and it's giving me a big headache honestly, always 100%, that's why I am going for the 12 th gen, so I think I am going to stick with that, but just the graphics card maybe it's good idea to drop it until I get a decent one, I am not sure, just because looking through the reviews and stuff everyone seems to hate this card, is either I drop it and wait a bit before getting a 3080 or get the 3070, maybe 3070Ti, and stick with it for couple of years, what do you think?To save a couple of £100 is quite easy. If you transfer your license, as suggested above, that gets you in the ball park.
Your fairly modest uses across your various softwares will easily be handled by the 12600k. The 12700 was just to get that extra punch. It's not necessary at all. The rest of the build is still well suited.
You could drop the 3060 and see if you could purchase it elsewhere and fit yourself. I would make sure the savings were going to be pretty significant though if you aren't comfortable with fitting components. The GPU is fairly straight forward but the last thing you want is fear.
Intel® Core™ i5 10-Core Processor i5-12600K (3.7GHz) 20MB Cache
ASUS® TUF GAMING Z690-PLUS WIFI D4 (LGA1700, USB 3.2, PCIe 5.0) - ARGB Ready
Corsair iCUE H100i RGB PRO XT Hydro Series High Performance CPU Cooler
NO OPERATING SYSTEM REQUIRED
NO RECOVERY MEDIA REQUIRED
Microsoft® Edge
Price: £1,674.00 including VAT and Delivery
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/intel-z690-pc/wgBRxSJry8/
