Spec help for Home mini PC please
oimee
Hi there - I am going round in circles a bit looking for an ideal solution for my new home PC.
could anyone recommend a spec for the following:
- preferably a mini PC
- for home use - word processing/web browsing/light photo editing plus some art and design
- with DVD/CD burner and card reader
- lots of storage for photos and some music
- it won't be used for gaming or videos (bar the odd you tube or iplayer clip)
I want it to be powerful but without breaking the bank
I've been thinking of getting an SSD for running Windows/software, and a 2TB black caviar for storage - does that sound like a good idea?
This is the spec I’ve come up with – is it more than I need? It’s also a bit more than I’d like to spend – its £620 before vat and was looking for something more like £500.
Any ideas gratefully received!
Inwin Mini-ITX BM643 Case + 160W PSU
Intel® Core™i7 Quad Core Processor i7-3770T (2.50GHz) 8MB Cache
ASUS® P8H61-I: Mini-ITX, LG1155, USB 3.0, SATA 3GBs
4GB SAMSUNG DUAL-DDR3 1333MHz (1 X 4GB)
Intel Graphics Media Accelerator HD + Clear Video HD Technology
Memory - 1st Hard Disk
120GB KINGSTON HYPERX 3K SSD, SATA 6 Gb/s (upto 555MB/sR | 510MB/sW)
2nd Hard Disk
2TB WD CAVIAR BLACK WD2002FAEX, SATA 6 Gb/s, 64MB CACHE (7200rpm)
1st DVD/BLU-RAY Drive
Network Facilities
2 x USB 3.0 PORTS + 4 x USB 2.0 PORTS AS STANDARD
Genuine Windows 7 Home Premium 64 Bit w/SP1 - inc DVD & Licence
keynes
You could go with an i5 if you wish to lower the price. I don't think your motherboard supports SATA 6gb/s, you may want to consider the 128gb Kingston SSD v200 instead.
