Just got my tower, arrived yesterday, everything so far so good. Although I noticed last night
that when i plug the headphones into the front panel of the tower (Fractal Define S Case), there is a
really annoying buzzing and static noise (with or without sound coming from the computer) in the
headphones but doesnt happen when i plug it into the back only the front.
Im slightly nervous about taking the whole front panel off with wires for IO still attached, seems like a bit of a tricky case to check the
front wiring. Should i check the sound connector on the motherboard as well? First timer custom pc owner, so really have no idea what im doing.
I bought a ground loop isolator last night (which will be delivered this week) in the hope that it might take away the static noise from the port, can anyone lend any advice if they have come across similar issues?
Thanks a lot.
Thanks a lot.
