Stuttering plz help | PCSPECIALIST
Stuttering plz help
Hello and happy new year, i have a windows 10 pc which is a monitor stand alone pc, it has a really confusing each 2 seconds stutter for like 1 second or half, ive used avast, malwarebytes and many other pc fix software but i dont manage to get a handle of any solution, i also tryed defrag, corrupt file fixes and every type of solution i could think of but nothing seems to do the trick, ill gladly give as many details as possible of my pc but i rly need some help, ill be waiting for any type of response, thx in advance.
Huntsman
Is this a PCSpecialist PC?
Ive tryed the software Driver Easy wich did the best monitoring of my pc problems and still no solution, pc specs are Asustek all in one ET2230A PC Series, AMD A6-6310 APU with AMD Radeon R4 Graphics 1.80GHz, 6.00GB (4.95 Gb usable) 64-Bit running Windows 10 Home
Huntsman
As PCS sell custom desktops and laptops, we can't advise on self builds or competitior builds, you may want to check out Toms Hardware which is an open forum.
I've studied for 2 years informatic apart of as a hobbie so im not just a random, i know the basics but i cant find what causes the problem, i have noticed that gpu spikes to basically 100% when it stutters but cant fix it in any way.. Im rly lost ive been trying to adress it my self for 2 days, only thing i havent tried is a format but i dont want to loose my music, pictures and personal files, any help is appreciated i dont mind trying again what i already have or any new solutions.
