Suitable Low-Profile Vesa Mount for an AOC I2769VM 27" IPS Monitor
Tiger Feet
Hi all,
I have recently purchased an AOC I2769VM 27" IPS Monitor. I am now on the hunt for a low-profile VESA wall bracket that will accommodate the monitor. The Vesa measurements on the back of the monitor are 75mm x 75mm.
I would want a low profile bracket that keeps the monitor as close to the wall as possible and allow cables to fit reasonably easy up at the back of the bracket to connect to the monitor.
Has anybody got one of these monitors on the wall and if so, could you recommend a wall bracket suitable for my purposes please?
Thanks
jerpers
Master
With a quick google of that monitor, your biggest problem would be that the cables come straight out of the back of the monitor. I would suggest looking at some right angle connectors and a right angled kettle lead. This will allow you to work out the minimum distance from the wall it can be and then shop from there.
