System freeze and GPU crashing
Skylinefx
My laptop specs:
Core i7 2630qm (2.00GHz)
GeForce 555M - 2GB
4GB SAMSUNG 1333MHz SODIMM DDR3 MEMORY
500GB WD SCORPIO BLACK
I just got Adobe After Effects CS5.5. After using it for about 10 minutes I my system completely froze and I couldn't even move the mouse, so had to hold the power button to turn off. No errors after turned back on.
Using After Effects again today, after about 5 minutes of editing/experimenting my Nvidia GPU will crash.
Today I have discovered that I can finally update my drivers via the Nvidia website to the latest version. Updated, restarted. Used After Effects and it crashed again after lasting a bit longer.
I also have Photoshop CS5 and Dreamweaver CS5. Both work without any problems. In fact, all other programs and games work properly.
What's the problem?!
Skylinefx
OpenGL is turned off in After Effects options. I can't even turn it on because it says it's not supported...
