temperature i5-760 @3.80 with titan fenrir extreme direct touch copper cpu cooler
Gishank
It should be fine, though I personally would advise you to make sure you have chosen a case with sufficient airflow and not one of those steel furnace things.
aresius
ok i take this case
COOLERMASTER HAF 922 MID TOWER GAMING CASE (3 fun , 2x200mm and 1x120mm)
Meds
At 100% load (prime95 CPU Stress Test), I wouldn't expect an i5 760 @ 3.8GHz to exceed 80/85 degrees with the Titan Fenrir.
Idle: around 45 degrees
Intense use/gamimg: around 60 degrees
The abient temperature of the room will also affect the temperatures along with the air circulation around the PC - dont put it in a cupboard/enclosed desk-type thing.
