The monitor speakers wont work with DVI or a DVI to HDMI Adaptor,it needs to be a straight HDMI to HDMI connection,or simply use an audio cable,just connect it from your sound card to the audio input on the monitor as with normal speakers.I read somewhere that DVI can't produce sound independently. The monitor I chose has built in speakers, but will they actually be functional if the monitor is connected simply via the DVI? Sorry if this is a stupid question. :wacko:
The monitor speakers wont work with DVI or a DVI to HDMI Adaptor,it needs to be a straight HDMI to HDMI connection.
I think that only works with some older cards,I could be wrong thoughI don't think that's quite right, you can get audio out through a DVI-HDMI (I can on my 690s). I think the graphics card needs to be HDCP compliant (most modern ones are) for that to work.
HDCP has nothing to do with audio far as I know,it's to do with copy right protection.
