Hello
I have had my pc from Feburary 2013, and it has worked brilliant until recently. 4 Week ago it started doing crashing to desktop with my game (WoW) vanishing off task bar, then reappearing and loading up again. Thought nothing of it. Then it started freezing. Thinking it needed a clean, I pull the pc apart and dust it. Worked fine up until now. Same thing happening, freezing. Again pulled it apart and cleaned it, even though there was hardly any dust, including PSU. Keeps on hanging when playing any games, but I can leave it on desktop all day no problem. Am also receiving the message gfx driver stopped responding and has been recovered. My spec is as follows
Case AeroCool Qx-2000 Gaming Cube Case
Processor (CPU) Intel® Core™i5 Quad Core Processor i5-3470 (3.2GHz) 6MB Cache
Motherboard ASUS® P8H77-I: Mini-ITX, LG1155, USB 3.0, SATA 6GBs
Memory (RAM) 16GB SAMSUNG DUAL-DDR3 1333MHz (2 X 8GB)
Graphics Card 2GB NVIDIA GEFORCE GTX 660 Ti - 2 DVI, HDMI, DP - 3D Vision Ready
Memory - 1st Hard Disk 120GB INTEL® 520 SERIES SSD, SATA 6 Gb/s (upto 550MB/sR |
520MB/sW)
2nd Hard Disk 1TB 3.5" SATA-III 6GB/s HDD 7200RPM 32MB CACHE
1st DVD/BLU-RAY Drive 10x BLU-RAY ROM DRIVE, 16x DVD ±R/±RW
Power Supply 450W Quiet 80 PLUS Dual Rail PSU + 120mm Case Fan
Processor Cooling INTEL SOCKET LGA1155 STANDARD CPU COOLER
Network Facilities 10/100/1000 GIGABIT LAN PORT - AS STANDARD ON ALL PCs
USB Options 6 x USB 2.0 PORTS @ BACK PANEL (MIN 2 FRONT PORTS) AS
STANDARD
Modem NONE, I WILL BE USING BROADBAND
Operating System Genuine Windows 7 Home Premium 64 Bit w/SP1 - inc DVD & Licence
(£79)
On nvidia's own website they said the min required psu is 450. When buying the pc was told in a pop up that 450W was fine and this included a 20% margin. Should the PSU not be higher? I trusted that 450 was correct as advised but it seems a bit low? Since games are more demanding making the gfx work harder, is it needing more juice than I can give it? Or is the gfx faulty? I have done all the standard stuff with drivers etc to no avail.
520MB/sW)
STANDARD
(£79)
