Touchpad problems
Scanian
Bump, anyone else have any ideas?
I am having the same issue. It's not a huge issue since I always use an external mouse anyway, but it is annoying and the link above isn't very helpful since it doesn't even show up in Device Manager. Have you managed to solve the problem lately?
If the mousepad isn’t showing in device manager it’s because it disabled. There’s a Hotkey to enable and disable it.
Now you are insulting my intelligence. :)
You don't think I've tried that?
Worth mentioning if you have, we're not mind readers.
If it's not enabling, then it's either failed or the hotkey is not working. Are any of your other hotkeys working?
Scanian
All hotkeys are working as they should, including this one, insofar as showing "Touch pad on" and "Touch pad off" when toggling. I can also tell you that I have spent hours googling for a solution, testing many different tips. On forums for HP, Lenovo, Dell, Acer, Asus etc, they have threads about this, but no solution. But it doesn't necessarily have to be a Touchpad although it's most common. Others have issues with the keyboard or touch screen.
There are no unknown devices in device manager?
Nope. Only a warning sign on "I2C HID Device" with error code 10.
Well that's pretty catastrophic. A HID device is a Human Input Device (mouse, touchpad, keyboard, etc.) and a code 10 means the device could not start.
If you're feeling brave you can try the old trick of deleting the upper and lower filters* in the registry for that device - but make a backup before you do. See here for details on how to do this - be certain you're working with the right device, they're identified by GUIDs so you need to find the GUID for your device with a code 10 (it's probably 4D36E96F-E325-11CE-BFC1-08002BE10318 but it's down to you to check that).
*Filters are front end and back end components of drivers, the upper filters are called before the driver and the lower filters are called after the driver. They are used to modify the actions of the driver in subtle ways that may or may not be either useful or needed - and like bad driver code they can cause issues.
Scanian
Thanks for the tip, but I already read about that too, and there were upper or lower filters to begin with.
The most frusttrating thing about this, is that it must just be some driver and Windows 10 combination that causes this. Probably some erroneous .inf file is causing it, so sending the computer back for repairs won't do any good. But as I said, I am practically using an external mouse 99.9% of the time anyway. But there are times when I could use the Touchpad, and it is also bloody annoying.
Scanian
The mouse is separate to the touchpad. Usually the touchpad will be a synaptics driver.
What's the chassis model number? It will be on a label on the underside of the laptop?
Hi Spydertracks,
Since I have the same problem, I wonder what your answer would be if I told you that my chassis model is P970EN.
Thanks in advance.
Hi Spydertracks,
Thanks in advance.
Is this a pcspecialist system?
Can you post your full specs from the order page?
Scanian
Yes, it is a PCSpecialist Defiance V. Attaching the specs. Unfortunately I only get them in Swedish, but maybe you can make out the details anyway.
Scanian
Can you copy the text, we can't open PDF's as they can contain viruses.
Alright, here you go. I have added a 1TB M.2 drive myself, but the issue precedes that.
Visar orderreferens 1658247
Chassis och skärmDefiance Series: 17.3" Matt Full HD 144Hz 72% NTSC LED Widescreen (1920x1080)
Processor (CPU)Intel® Core™ i7 6-kärnig processor 8750H (2,2GHz, 4,1GHz turbo)
Minne (RAM)32GB Corsair 2400MHz SODIMM DDR4 (2 x 16GB)
GrafikkortNVIDIA® GeForce® RTX 2070 Max-Q - 8.0GB GDDR6 Video RAM - DirectX® 12.1
Ändra till: NVIDIA® GeForce® RTX 2080 Max-Q - 8.0GB GDDR6 Video RAM - DirectX® 12.1
1:a lagringsenhetenKRÄVS EJ
1:a M.2 SSD-enheten512 GB PCS PCIe SSD M.2 (2000 MB/R, 1100 MB/W)
MinneskortläsareIntegrerad 6-i-1 Kortläsare (SD /Mini SD/ SDHC / SDXC / MMC / RSMMC)
AC-adapter1 x 180W AC Adapter
Strömkabel1 x 1 meter Cloverleaf europeisk strömkabel
BatteriDefiance Series 4-Cells Litium-Jonbatteri (62WH)
Termisk pastaARCTIC MX-4 EXTREME TERMISK MASSA
Ljudkort2 Kanaler High Definition Audio + MIC/Headphone Jack
Bluetooth och trådlösGIGABIT LAN & WIRELESS INTEL® AC-9260 M.2 (1,73 Gbps, 802.11AC) +BT 5.0
Ändra till: GIGABIT LAN & WIRELESS INTEL® Wi-Fi 6 AX200 (2,4 Gbps) + BT 5.0
USB-/Thunderbolt-alternativ2 x USB 3.1-PORTAR (Typ C) + 2 x USB 3.1-PORTAR
TangentbordsspråkRGB-BAKGRUNDSBELYST SVENSKT / FINSKT TANGENTBORD
OperativsystemWindows 10 Professional 64 Bit - inc. Enskild Licens
OperativsystemsspråkUSA - Amerikansk Engelska
Windows återställningsmediaWindows 10-återställningsavbildning på flera språk - levereras på USB-enhet
Office-programGRATIS 30 dagars testperiod av Microsoft® Office® 365 (Operativsystem krävs)
AntivirusBullGuard™ Internet Security - kostnadsfri 90 dagars licens inkl. Spelarläge
WebbläsareMicrosoft® Edge (Windows 10 Only)
Mus för bärbar datorMicrosoft Wireless Mobile Mouse 4000
WebbkameraINTEGRERAD 1MP HD WEBBKAMERA
Garanti3 års Guldgaranti (2 år upphämtning & retur, 2 år delar, 3 år arbete)
Leverans4 - 5 DAGS LEVERANS TILL SVERIGE
ByggtidStandardstruktur - Cirka 6 till 8 arbetsdagar
VälkomstbokPCSpecialist Välkomstbok - Sverige
Detaljerad specifikation
Mått & vikt
Mått (B x D x H)398,6 mm x 268 mm x 19,9 mm
Vikt2,5 kg
FärgSvart
Chipset
ProcessorstödStödjer nionde generationens Intel Core-processorer
Minne
MinnestypStödjer DDR4 2666MHz
Antal moduler2 x 1 GB-/2 GB-/4 GB-/8 GB-/16 GB-moduler
Maximal minnesstorlek32 GB
Hårdiskkapacitet
Hårddisktyp1 x 7 mm, 2,5" S-ATA HDD-stöd
M.2-port2 x M.2 2280 SSD-uttag, 1 x WLAN M.2 2230
Skärm & grafik
GrafikVal av grafikkort - se konfigurator.
Skärmstorlek17,3 tums bredbildsskärm
Ursprunglig/maximal upplösning1920 x 1080
Uppdateringsfrekvens144 Hz
Ljud
ChipsetHögdefinitionsljud med SoundBlasterX® Pro-Gaming 360˚
Kanaler2-kanals HD-ljud
Anslutningar1 x uttag för hörlurs-/mikrofon-uttag, 1 x mikrofon-/optiskt S/PDIF-uttag
HögtalareTvå inbyggda högtalare
Inbyggd mikrofonJa, arraymikrofon
Kommunikationer
Stöd för trådlöst nätverkTrådlös LAN 802.11AC/B/G/N (M.2-gränssnitt)
Bluetooth-stödStöd för Bluetooth V 5.0-modul
Tangentbord och mus
TangenterTangentbord med RGB-bakbelysning
SpråkstödStöd för flera språk
Pekenhet | StyrplattaStyrplatta med pekare och vänster-/högerklick
Bakgrundsbelyst tangentbordJa
Minneskortläsare
Minneskortläsare6-i-1 kortläsare (MMC/RSMMC/SD/mini/SD/SDHC/SDXC)
Portar
LAN1 x RJ45-uttag
USB2 x USB 3.1-uttag (typ C), 2 x USB 3.1-uttag
Skärm1 x HDMI, 1 x minidisplayanslutning, 1 x USB-C (DP 1.3)
Mikrofoningång1
Hörlursutgång1
Likström in1
S/PDIF1 x S/PDIF-utgång (via mikrofonuttag)
Batteri & sladd
Batterikapacitet4-cells smart litiumjonbatteripack på 62 Wh
Normal batterilivslängdUpp till 5 timmar (i UMA-läge)
Strömkabel och AC-adapter1 x kabel medföljer växelströmsadapter
Säkerhet
KensingtonlåsJa
Scanian
Have you done anything like reinstall or reset windows since you've had it?
What AV do you have installed?
Have you used any driver updater software?
Only Windows Defender. I am pretty careful and never run any untrusted software. I haven't reset the computer. Updates are only from Windows update and updated drivers from Clevo. However, since the problem occurred I've tried a few things, like rolling back the drivers for SerialIO and HIDFilter to older ones which didn't help.
But I am pretty sure that it occurred with some Windows update or maybe the hardware is broke. The problem didn't start with any manual driver installation by me. If a had to take a guess, it happened in conjunction with a new Windows 10 release.
