When doing physics test 3dmark or anything else that stresses cpu. The cpu goes to 3,2 ghz all 4 cores.
If I understand correctly the processor should be able to go 3,6 ghz all 4 cores (and higher if cores not used)
Aida64 says turbo boost supported (disabled)
The bios does not allow me to enable or disable it, as the bios is SEVERLY limited in options (no idea why)
Can anyone help?
Or am I better sending this laptop back..
Can anyone help?
