USB Microphone Static
JamesMLB
This is a problem which I've had in my PCSpecialist since I got it in 2011.. Normally I would use a USB Headset, such as those of Logitech and Turtle Beach, and I could cure the static by plugging the USB into a usb phone charger and putting the 3.5mm jacks in my computer.
But now I have a Blue Yeti. It is completely USB and therefore relies on its connection. When I record audio, through whatever program on THIS computer, there is static. Does anyone have a solution? I might try putting it in a different computer to test if it is the computer and not the microphone. Anyone got a fix though?
Any help would be great!
- JamesMLB
spikopsycho
JamesMLB
The hub arrived and it hasn't solved the problem, instead has now added a charging like noise to the recording.. anyone got any other solutions?
spikopsycho
Sorry to hear that. I'm out of ideas here, maybe someone else will have some ideas though.
The reason I asked about whether its a hum/or hiss was as I was reading about mains hum - http://en.wikipedia.org/wiki/Mains_hum#Tone
There's two different tones on there, but as you say the hub didn't help at at all. Have you/can you tried the mic on another system and see of you have the same problem?
JamesMLB
Nope not really.. I've just been playing around with the settings a bit and I had the levels before at 20-25 and the gain at the lowest setting, I then just tried the levels at a lower number, but with a higher gain and it elminated the noise pretty much :)
