Hi all
Recently when booting laptop (vortex IV win 7 64 bit) randomly the usb ports seem to fail (wireless mouse fails to initiate) although i can use the track pad.
However when i try to shut down the pc it stays on "shutting down" for ages and i have to do a hard shut down with the power button to turn it off, and once when i left if running shutdown for > 10 minutes it eventually blue screened to " DRIVE_POWER_STATE_FAILURE. The problem started as occasional but is now at a lot of bootups. It's getting a pain having to reboot firstly into safe mode (as i'm offered the various safe mode options) and then finally a normal boot.
Looking in event viewer shows multiple errors but the first listed is
USB\Vid_1C7A&PID_0603.......... and references to WUDFRd failing to load for the device. Based on some googling advice i've tried ending "WUDFRd" in device manager but it reappears again immediately.
I think the culprit is the fingerprint reader (which i don't use). I've tried disabling it, but it still seems to load up as shown by usb icon in the task bar, also i can't "eject" it via said icon, tells me to close programs using it first.
I'm a bit reluctant to try to uninstall it completely as i'm a bit out of my depth and don't want to foobar things completely. Any ideas gratefully received.
