Build time took about 15days, regular updates were good. Delivery was really good from DPD and they texted the morning of delivery with a 1hour slot (it arrived 5 mins after the text!). It was well packed and double boxed, no problems there, keeping the box of course in case it needs to be sent away ever.
First impressions were it's hefty, as previously mentioned! It is very well build though, nice and solid so will hopefully last a looooong time. Keyboard looks really good and have got used to the half height return button quickly. Had a little trouble when it first booted up, after entering Windows 8 key and selecting my wireless router during setup it sat with blue screen for ages, in the end I rebooted and skipped this step, connecting to the wireless in Windows and it was fine. Windows 8 takes a bit of getting used to but that's not really laptop related.
Good bits:
Solid, boots up in <10seconds, powerful, processes 16 RAW images in Lightroom 5.2 without crashing! (unlike previous PC), looks good when connected to 1080p TV.
Ok bits:
Not 100% sure about the screen yet, have tried to calibrate it etc. but think it needs more work, colours aren't quite right and contrast isn't as good when connected to tv, think it needs more effort to calibrate, tips welcomed! A little prone to fingerprints! Especially if you have an 18month old daughter who loves laptops.... The only other thing I'd have liked was a scroll bar on the right hand side of the touchpad, we have one on our cheapo Tesco Acer laptop and it's pretty handy.
Bad bits:
Speakers are pretty poor for an expensive laptop, these should be better for the price. Haven't fully tested battery life yet but with everything turned low reckon it will be <2hours, but it does have a huge screen so can't really complain.
Overall good service from PC Specialist, glad I got a 240Gb SSD for primary drive, 750Gb backup.
Have attached a few quick pictures, JPEGs straight out the camera with no editing. Pentax K-r on 35mm 2.4 lens, handheld at ISO1600 if anyone is interested.
Chassis & Display Vortex Series: 17.3" Matte Full HD LED Widescreen (1920x1080)
Processor (CPU) Intel® Core™i7 Quad Core Mobile Processor i7-4700MQ (2.40GHz) 6MB
Memory (RAM) 16GB KINGSTON HYPER-X GENESIS 1600MHz SODIMM DDR3 (2 x 8GB)
Graphics Card AMD® Radeon® HD 8970M - 4GB DDR5 Video RAM - DirectX® 11
Memory - 1st Hard Disk 240GB INTEL® 335 SERIES SSD,SATA 6Gb/s(upto 500MB/sR|450MB/sW) SPECIAL
2nd Hard Disk 750GB WD SCORPIO BLACK WD7500BPKX, SATA 6 Gb/s, 16MB CACHE (7200 rpm)
1st DVD/BLU-RAY Drive 6x BLURAY WRITER, 8x DVD ±R/±RW & CYBERLINK SOFTWARE
Memory Card Reader Internal 9 in 1 Card Reader (MMC/RSMMC/SD: Mini, XC & HC/MS: Pro & Duo)
