Wifi adapter failing after sleep mode?
lurkybuh
Hi, hoping someone might have some ideas. I have a one year old desktop which has been having wifi issues for the past couple of weeks. If the PC is allowed to go into sleep mode, I lose wifi connection almost completely or it slows to a crawl. Restarting fixes it- until the PC goes to sleep again.
When it cuts out I get dozens of the following errors in event viewer:
6062 - Lso was triggered
5007 - TX/CMD timeout (TfdQueue hanged)
Intel(R) Wi-Fi 6 AX200 160MHz : Has encountered an internal error and has failed.
Intel(R) Wi-Fi 6 AX200 160MHz : Has determined that the network adapter is not functioning properly.
What I've tried so far to fix it:
-Turned off 'allow the computer to turn off this device to save power' in power management settings
-Uninstalled wifi adaptor and restarted PC so that it reinstalls drivers
-Tried rolling back to previous drivers in case windows update did something odd
-Replaced default drivers with latest Intel ones
-Run the troubleshooter- it finds nothing wrong with the connection or device
-Virus and malware scans, disk cleanup, defrag... (sheer desperation at this point)
None of these worked. (or I thought they did, as the connection is fine after restarting... until it goes into sleep mode. Then boom, no more internet.)
I'm starting to think the wireless network card might be on the way out, but I hope not. Any suggestions? :(
Here's my specs:
ASUS® PRIME B550-PLUS (DDR4, USB 3.2, 6Gb/s) - ARGB Ready!
8GB AMD RADEON™ RX 5700 XT - HDMI, DP - DX® 12
256GB PCS 2.5" SSD, SATA 6 Gb (500MB/R, 400MB/W)
DVD/BLU-RAY Drive
PCS FrostFlow 100 V2 Series High Performance CPU Cooler (AMD)
LED Lighting
50cm Blue LED Strip
Extra Case Fans
LSO is the Large Send Offload feature of the adapter. Go into the advanced options for the adapter in Device Manager and look for a Large Send Offload option, if it's there set it to disabled. The other thing I would try is to download inSSIDer3 (free) and use that to find the least busy channel in your area and set the router to that channel.
