Hello,
I've had this desktop for about 6 month now from PCspecialist but since October i have been having issues that the wifi connection would randomly disconnects and get the "no internet secure" after a driver update this seems to had stop but come December and now I am having a similar issue again where the wifi will cut out a random and then reconnect after a minute or two it seems to happen more fequently with online games checking the event viewer each time this has happened i get this warning:
The description for Event ID 6062 from source Netwtw14 cannot be found. Either the component that raises this event is not installed on your local computer or the installation is corrupted. You can install or repair the component on the local computer.
If the event originated on another computer, the display information had to be saved with the event.
The following information was included with the event:
\Device\NDMP1
Intel(R) Wi-Fi 6E AX211 160MHz
The message resource is present but the message was not found in the message table
I have tried a clean install of the driver and rolling back to a old driver as well as the using CMD with netsh/ipconfig commands to no effect. Only option i have not tried yet is a complete reset of windows 11.
No other devices in my home are having this issue.
Edit 2 - Done a windows reset, looked like it solved at first but still happening.
Edit 3 - So trying replacing the antenna with a spare i found wifi seems to be more stable.
Edit 4 - Issue reappeared tonight using a different antenna so scratch that idea. I'm out of ideas at this point worst case that i can think of is something has happened to the actual wifi card.
Spec
Intel® Core™ i7 16-Core Processor i7-13700K (Up to 5.4GHz) 30MB Cache
ASUS® ROG STRIX Z790-F GAMING WIFI (LGA1700, DDR5, PCIe 5.0, Wi-Fi 6E)
16GB NVIDIA GEFORCE RTX 4080 - HDMI, DP, LHR
1TB SAMSUNG 990 PRO M.2, PCIe 4.0 NVMe (up to 7450MB/R, 6900MB/W)
2nd M.2 SSD Drive
2TB SAMSUNG 990 PRO M.2, PCIe 4.0 NVMe (up to 7450MB/R, 6900MB/W)
\Device\NDMP1
Spec
2nd M.2 SSD Drive
