Thank you for that, just have a little question, at the moment I use a Gsync monitor, do I require a Gsync to control the fps output in the Nvidia control panel global settings, or can that be changed regardless of Gsync or not? ThanksSo long as you're optimising settings the 3080 will do pretty well on a 4k 144Hz monitor, but there are some obvious newer games that may struggle without severely reducing settings such as Hogwarts, CyberPunk, those kinds of games.
Gymsync synchronises the fps of the pc to the hz of the monitor for less tearing. You don't need to worry about FPS at all, gsync does it for youThank you for that, just have a little question, at the moment I use a Gsync monitor, do I require a Gsync to control the fps output in the Nvidia control panel global settings, or can that be changed regardless of Gsync or not? Thanks
