Will this work with oculus rift s? | PCSPECIALIST
dodge83
any special comments about the hardware choice, please add criticism praise for parts used as new
Total Order Price£1,577.00
Showing Quote Reference 1581965
CaseCORSAIR SPEC-DELTA RGB MID TOWER GAMING CASE
Overclocked CPUOverclocked AMD Ryzen 7 3800X 8 Core (3.9 GHz @ up to 4.4 GHz)
MotherboardASUS® CROSSHAIR VIII HERO (DDR4, PCIe 4.0, CrossFireX/SLI) - RGB Ready!
Memory (RAM)16GB Corsair VENGEANCE DDR4 2666MHz (4 x 4GB)
Graphics Card4GB AMD RADEON™ RX 570 - HDMI, DP - DX® 12
1st Storage Drive500GB SEAGATE BARRACUDA 2.5" SSD, (upto 560MB/sR | 535MB/sW)
2nd Storage Drive1TB SEAGATE BARRACUDA SATA-III 3.5" HDD, 6GB/s, 7200RPM, 64MB CACHE
DVD/BLU-RAY DriveNOT REQUIRED
Memory Card ReaderUSB 3.0 EXTERNAL SD/MICRO SD CARD READER
Processor CoolingCorsair H80i V2 Hydro Cooler w/ PCS Ultra Quiet Fans
Thermal PasteCOOLER MASTER MASTERGEL MAKER THERMAL COMPOUND
Wireless/Wired NetworkingWIRELESS 802.11N 300Mbps/2.4GHz PCI-E CARD
USB/Thunderbolt Options2 PORT (2 x TYPE A) USB 3.1 PCI-E CARD + STANDARD USB PORTS
Operating SystemGenuine Windows 10 Home 64 Bit - inc. Single Licence [KUK-00001]
1) faster RAM, in 2x8gb format
2) The R7 3800x is £70 or so more than an R7 3700x and the performance is virtually the same
3) overclocking Ryzen CPUs doesn't get you much extra performance, and can actually hurt performance depending how it's done. I'd buy at stock speeds with a decent cooler and just let the CPU boost itself tbh...
4) the GPU is modest
5) The case is very closed up at the front and not ideal
6) The USB card probably isn't needed? The mobo has plenty of USB ports and USB 3.1 Gen 2 is on a different controller + has more bandwidth anyway.
7) That motherboard is not remotely worth buying for the uses you've stated (high end gaming)
8) arguably there's no point to the R7 3700x over the R6 3600 for gaming. And if buying a 3700x, the 9700k should perhaps be considered instead...
If you've already bought this, cancel the order and start over.
Your spec was apparently a bit under £1600:
£1600 with an RX 570 for VR gaming :S Ouch.
Instead:
COOLERMASTER MASTERBOX K500 RGB GAMING CASE
ASUS® TUF X570-PLUS GAMING (USB 3.2 Gen 2, PCIe 4.0, CrossFireX) - RGB Ready!
Get Control & Wolfenstein: Young Blood w/ select GeForce RTX GPUs!
DVD/BLU-RAY Drive
NOT REQUIRED
Corsair H100x Hydro Cooler w/ PCS Ultra Quiet Fans
Standard Build - Approximately 10 to 14 working days
Price: £1,571.00 including VAT and Delivery
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/amd-am4-gen3-pc/J!HCEq46tz/
Arguably the R6 3600 should be opted for instead.
samwil
Instead:
DVD/BLU-RAY Drive
NOT REQUIRED
You can quite easily get a 70 super at that price range, so reconsider your choice of CPU as previously mentioned also.
