So bit the bullet, did the upgrade , all seems good , apart from the cpu temp fluctuating , kind of spiking up and down even on desktop . In win 10 i was sitting around 40c roughly , but as i look at my icue now its spiking from anything from 50 -65c, up and down fans ramp then fans off, during gaming it does not go over 70c which was normal for me , I only had this start happening since the upgrade.
I have tried reinstall the updates through windows , i have also installed chipset drivers, installed gpu drivers again . and when i go to task manager i can not see anything high cpu usage at all . I have also done all latest updates for my i cue and cpu cooler through icue . I am going to be getting the system upgraded soon through pcs , but would like to know what has caused this in the upgrade .
I have looked online but cant find any single solution , was just wondering if anyone has known of a similar issue after win 11 upgrade . I have also made sure power in windows is set to balanced . The coolant temp does not increase at all, it seems normal but its just the spikes in temp up and down i cant work it out .
