MeveM
Hello again dear PCS members.
Been a while since I was last on here but it seems I've come across a problem with my network card that's been there since day one. I never really bothered to get it fixed with the warrenty while it was active as I simply opted to use a network cable instead. Thought it'd eventually go away
So here's my problem, similar to this thread but the fix did not work for me: https://www.pcspecialist.co.uk/forums/showthread.php?11094-Wireless-Card-Problem
My card is: ONBOARD GIGABIT LAN & WIRELESS 802.11N 300Mbps PCI CARD
What I'm experiencing is that 50% of the times I start my PC it gets into windows, tries to load up the internet connection and I get a bluescreen. I can't remember what the bluescreen says nor do I remember how to make it so it doesn't restart before I can read it. It then restarts itself and usually starts working properly again after 1-2 restarts. It then works perfectly fine except for the odd disconnection from the internet. (Very rare).
I have now moved house and the Virgin box is too far away for me to use a network cable. I'm only worried about the reboots in case it damages my PC.
I have tried reinstalling it multiple times, I have tried uninstalling it and letting windows install all the drivers itself without using the CD provided with the card, I also noted about a week ago that there was a windows update that actually included a update for my network card but it did nothing to sort my problem.
Anyone got any ideas?
