ok...overclocked my gtx 460 ,played stalker for a bout 10 mins .stable ,fine,great....then the game stops,goes off,so i then try in steam to play that gamr#e and others and i couldnt.....so changed settings in g.card back and tried again,couldnt play games,....so i installed the graphics driver again, than aftr that i used some software,cant remeber name which is supposed to clean up driver bits left over ,in the options of this software i chose nvidia display......im a bit muddled cant remember exactlyw hat happpened afre#er that --my problem now is ,1- i cant get display in hdmi ,previosly when i did all of the above it was in hdmi mode now i have to use vga[and its crap], 2 -there seems to be no nvidia driver intsalled,when i try and play stalker it says that'x-ray 1.6' engine has stopped working' and when other games were attemted to be loaded a prompt came up saying no video card wwas detected.....look i want to get my picture back in hdmi mode but i dont know how,i would assume i'd do it in the nvidia driver but i cant locate it[i think its not installed cos when i boot it up it prompts me to install the g card driver -so i try and it works fine but when it gets to the bit where you have to press finish i cant see the option because it is off screen...the screen size is messed up and i dont know how to change it,tried changing resolution in the control panel bit but the only way i know of changing the screen size was within the nvidia driver -which as i say does not seem to be installed........look ,the upshot is i want to have display in hdmi but cant ....sorry for this long ,convoluted post
