3600mhz RAM - Unstable
BT81
Press fn f1 🤦‍♂️
Back to the BIOS
Changed back to DOCP and 3200mhz
Literally where I started this morning - but with RGB 🤣🤣🤣🤣
B4zookaw
Ah! Was the keyboard one of the ones where the function keys are set to change brightness etc and to actually send a F1 you need to hold down Fn key?
sck451
Press fn f1 🤦‍♂️
Back to the BIOS
Ah, I did wonder if it was a keyboard issue! But I thought it couldn't be that.
I actually also have Corsair RAM I bought after purchase. It was supposed to be 3600MHz, but the DOCP profile came up with 3200MHz, and I've never bothered trying to work out if I could actually get the full speed out of it. After your experiences, I probably won't try...
BT81
I assume so 🤦‍♂️🤣
Well - if anyone else has this problem, I’ll know what to suggest :)
BT81
On the plus side - I decided to stick in the old ram as well (not that I need 32gb!)
And my start up time is 6.6 sec
Makes no difference to gaming etc - but a small victory ✌️
BT81
So - After a week. I thought I'd have 'another go' and ....suprise
Switched to 3600mhz, DCOP and boom. No problems since! :) Now - Have I noticed a difference. Er....nope haha
