Advice on build (updated)
MikeMcMillan953
This PC is primarily being built for gaming, and I'm not the most hardware savvy so any advice would be greatly appreciated. Coming in at the top of my budget of £1600. I'll be using an ASUS TUF Gaming VG249QL3A 24" monitor.
Many thanks :)
PCS PRISM TG WHITE ARGB MID TOWER CASE
Intel® Core™ i7 20-Core Processor i7-14700F (Up to 5.4GHz) 33MB Cache
GIGABYTE B660 DS3H DDR4 (rev. 1.0) (LGA1700, DDR4, PCIe 4.0)
32GB PCS PRO DDR4 3200MHz (1 x 32GB)
16GB NVIDIA GEFORCE RTX 4060 Ti - HDMI, DP, LHR
Graphics Card Support Bracket
2TB PCS PCIe M.2 SSD (3500 MB/R, 3100 MB/W)
1TB PCS PCIe M.2 SSD (3500 MB/R, 3200 MB/W)
CORSAIR 650W CX SERIES™ CX-650 POWER SUPPLY
CORSAIR H60x RGB ELITE HIGH PERFORMANCE CPU COOLER
Extra Case Fans
1 x PCS ARGB LED Fan
WIRELESS INTEL® Wi-Fi 6E AX210 2,400Mbps/5GHz, 300Mbps/2.4GHz PCI-E CARD + BT 5.0
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/intel-home-office-pc-V/w4sH8WMpJF/
MikeMcMillan953
Can I also ask, would it make much difference (to sound levels or cooling performance) to upgrade the case to a Fractal Pop Silent Case TG ?
Many thanks
This is a little over budget but it's a monster 1080p build. I would suggest that you don't want to stick with 1080p forever so I would have eyes on a monitor and GPU upgrade next year. The build will absolutely cater for that, all you will need is an appropriate GPU, you swap it out and sell the old one to recover some costs.
FRACTAL FOCUS 2 ARGB GAMING CASE (BLACK)
16GB AMD RADEON™ RX 7600 XT - HDMI, DP - DX® 12
CORSAIR H100x RGB ELITE HIGH PERFORMANCE CPU COOLER
ONBOARD 2.5Gbe LAN PORT
Price: £1,638.00 including VAT and Delivery
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/amd-am5-pc/HpQ4QxBfan/
Getting inside budget is easy, just forego the X3D chip (the X3D is the best gaming chip on the market but the 7700 isn't to be sniffed at). You could save a further £50 on the cooling if you wanted, as the 7700 doesn't need this level of cooling, but personally I would keep it as it'll allow you to upgrade the CPU to something beefier without having to upgrade the cooling also. The option is there though. Additionally, there's no real down side to over-shooting the cooling.
I wouldn't recommend any of the low end silent cases. The Define 7 is the only one with decent enough airflow IMO, and even then you need to be using an AIO to get the most out of it.
AMD Ryzen 7 7700 Eight Core CPU (3.8GHz-5.3GHz/40MB CACHE/AM5)
Price: £1,515.00 including VAT and Delivery
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/amd-am5-pc/b9xwT5RAVg/
