Am I good for cooling?
danyoualltohell
Hey there, finally dipping my toes into the world of PCs
Not looking for anything fancy, 1440 or 1080 is fine by me. Gaming is only one use case for this, it's gonna be a bit of a workhorse with general use and photoediting etc.
My main concern, after reading through a few posts is my case/fans? I don't really care about looks but I've heard this case can be excessively noisy and doesn't have PWM fans (but it does clearly state PWM, so maybe I was reading older posts? Or the case model has been updated?)
And I'm not sure if the additional two fans I've added to my order (to go in the top slots) are also gonna be dynamic or not, they just gonna be huffin at 100% the time?
It's the one part of the build where I really haven't got a clue, so any feedback appreciated.
PCS SPECTRUM G ARGB MID TOWER CASE (PWM)
Promotional Item
AMD Ryzen 5 7500F Six Core CPU (3.7GHz-5.0GHz/38MB CACHE/AM5)
32GB PCS PRO DDR5 4800MHz (2 x 16GB)
16GB AMD RADEON™ RX 7800 XT GAMING - HDMI, DP - DX® 12
Graphics Card Support Bracket
1TB PCS PCIe M.2 SSD (3500 MB/R, 3200 MB/W)
CORSAIR 550W CX SERIES™ CX-550 POWER SUPPLY
DeepCool AK400 Performance CPU Cooler ZERO DARK
Extra Case Fans
2 x 120mm PCS Black Case Fan
danyoualltohell
Monitor - Lenovo L28u-35- 2160/ 60Hz & one ancient 1080p Samsung 60hz HDMI thing.
Uses - 1080/1440 gaming - 4k media watching (streaming) - general usage - Photo Editing/Graphic Design
Max Budget - £1500ish
danyoualltohell
Promotional Item
Extra Case Fans
ONBOARD 2.5Gbe LAN PORT
Monitor Cables
2m DisplayPort Cable - DP (M) to DP (M)
SATURDAY DELIVERY TO UK MAINLAND (BEFORE 2PM)
Welcome Book
PCSpecialist Welcome Book
Logo Branding
PCSpecialist Logo
Packaging
PCS Trade Pack - New 2023
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/amd-am5-pc/9rKuDzpyB9/
The monitors aren't going to be ideal for your gaming uses. Only being 60hz is both good for performance and bad for visuals. It'll be easy to run a 60hz monitor but it's definitely going to be a bottleneck. 1440p won't scale well on a 4k monitor (it doesn't divide) so I would definitely steer clear of operating this way. You would be better placed to get yourself a monitor specific for gaming (replacing the 1080p one as the 4k is good for production).
There are many very poor choices in your configuration. I'm surprised that the only thing you picked up on was the case to be honest. I don't think the budget is there for a 7800XT build but I'll propose what I would look for in a system around that particular GPU with your use case in mind.
In the below I would prefer the 620 cooler so keep an eye in case that comes back in stock. The ideal selection would be the H100x, but the budget was too restrictive.
FRACTAL FOCUS 2 ARGB GAMING CASE (BLACK)
AMD Ryzen 7 7700 Eight Core CPU (3.8GHz-5.3GHz/40MB CACHE/AM5)
Monitor Cables
Price: £1,688.00 including VAT and Delivery
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/amd-am5-pc/wdWRgH7UdW/
The below gets you on target for the budget. The 4060Ti isn't a great 1440p GPU but it'll do a decent enough job. I've had to lower the CPU as well. This won't be an overly strong performer as a workhorse but it'll do fine for photoshop etc. The only down side for video editing or rendering would be time, you aren't going to have any other issues.
Same goes for the cooler. I would far prefer the 620.
AMD Ryzen 5 7600 Six Core CPU (4.0GHz-5.2GHz/38MB CACHE/AM5)
8GB NVIDIA GEFORCE RTX 4060 Ti - HDMI, DP, LHR
Monitor Cables
Price: £1,501.00 including VAT and Delivery
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/amd-am5-pc/xS5jEGuua9/
