DeadEyeDuk
Hi guys,
Had my new PC for a few weeks and there are a couple of things I wanted to see if you could shed some light on.
Firstly, when I turn on the PC, after a couple of seconds there is a short sharp "beep". It sounds like it is coming from nearer the front of the tower, but that is rather difficult to tell to be honest. What could this be? Should it be doing it? etc etc.
Secondly, my motherboard, ASUS® ROG STRIX Z270E GAMING: LG1151, USB 3.1, SATA 6GB, Wi-Fi - RGB Ready!, obviously has lights on it (as per the RGB bit no?), but these stay on after the PC is turned off. I did do a bit of Googling and there seems to be something that can be done to reduce power or something that will mean they don't stay on, but that was a bit over my head without further explanation.
Any thoughts on either?
Cheers
DED
Cheers
DED
