JUNI0R
Sorry for my late response, I've been travelling all day! Looks like Agent Cooper has got you an answer already. Technically the link will last for months, but not at that price. If you're not planning on buying straight away, saving the quote will save the price for 5 days, so if it increases, great, you've got it at a cheaper price. if it reduces, you just do a new quote for the lower price!Hey! Sorry for late response. Ok i have slightly figured it out. How long does the link last for? I am currently at work :/ (Work Sucks). Thank you for sharing your knowledge with me regarding the build I like it a looot
I believe you can also get a 360mm rad next to the mobo too, the 5000 series are monster cases 😂Ah, I stand corrected. (Though I'd still stick with the H115i in terms of value for money.)
If you'd rather a smaller screen you could go for a non-ultrawide version of that monitor called the AOC CQ27G2U. I own one and it's a fantastic experience (especially compared to 1080p 60hz which is what I came from 😂 ). It's a 27 inch monitor so it's slightly larger than what you're used to but you need a larger screen when you have a higher number of pixels. For your budget, I really wouldn't recommend 1080p (which is what you'd need for 24 inch screens). Going for this would also mean you could save on the GPU as you'd have less pixels to push (I'd swap to the standard 3070, instead of the 3070TI)Hey! So I check out the monitor AOC CU34G2X and realised its a 34 inch. I enjoy a normal size of 24’. Is there one within this size which you would recommend ?
