Woke up this morning and turned the pc on only for it to freeze on the 'asus motherboard - please press DEL to enter UEFI BIOS setting' screen.
Checked inside the PC and the Boot Device LED is on solid red (the on just to the right of it is solid green, as it usually is).
I have the P8Z77-V motherboard.
Have checked the manual but cant see a way to fix this issue?
One thing i do remember, i had a USB stick plugged in when i turned the pc on, as it was booting i pulled it out and plugged in my ipod shuffle) not sure if there is an issue iv caused from this?
Any ideas?
Thanks
Also the keyboard is unresponsive. Pressing delete does nothing, and pressing num lock/caps lock doesnt change the light indicating what 'locks' are active
Any ideas?
Thanks
