I'm planning to get a new laptop, once the second-generation i7s are actually available, but I'm a bit worried about the build quality. As I do a lot of writing on my laptop, keyboard quality is important to me; in particular, I can't abide keyboards that have give in the middle, squeaky hinges, or other mechanical issues. I don't mind paying extra for this, but I have trouble finding anyone who'll give me the option.
This has in the past led me to buy only apple's laptops (and then proceed to install linux on them..), on the basis that their build quality is consistently good. Unfortunately getting linux running well has only gotten harder over the years, and I don't expect the situation will improve. It's still an option, though.
So, I'm interested in both any other buyers' comments on the build quality of PCS' top-spec laptops, and.. also, from the administrators, a comment on your returns policy. If I were to buy a laptop from you, it'd have to come with a promise that it is either properly built in this manner, or I can return it - and yes, I'm aware that this is not your normal policy for custom laptops, but if you believe that your builds are good then you shouldn't have a problem with it.
I'm looking to spend quite a lot of money, here. Broken-by-design is just as bad as the other kinds of broken, and the lack of any comments on keyboard quality has me worried; I don't consider "average" to be good enough in that area, or any other; "top-spec" should cover the entire machine.
