staceyth07
I got my pc yesterday, since turning it on it keeps going loud then humming then loud again? I can’t turn my xmp to enabled! My fps is low on games? I’m getting annoyed with this pc! Please help before I return it
CaseWhen posting for Technical Support...
Hi all If you're here, it likely means you're having issues which is not good, so we want to help to make it much better as quickly as possible and get you back into full tilt gaming / rendering / production or whatever is your poison. It really helps us if we have the full system...www.pcspecialist.co.uk
Could you copy and paste the full specs please?
ThankuI’m not sure it’s terribly well configured. A 240mm budget AIO on the 14700k is going to struggle at the best of times, you really need a 360mm premium cooler.
The PSU as well is only just enough and lower tier than I would have thought appropriate.
I would suggests cancelling the order and getting some advice on something more suitable.
