I came home tonight and my pc has rebooted with a cpu over temperature error. Push F1 and it neither boots into windows or safe mode. The bios says the cpu temp is 85c and motherboard temp 30c.
I’ve opened the case and the heatsink was a bit wobbly (rotated a few degrees each way? – I moved about a week ago so maybe its got knocked?). I’ve removed the heatsink. Is the paste meant to stick between the cpu and the heatsink? Mine wasn’t.
How do I reapply the paste and is there anything I should know (I’ve not installed a CPU before). I’ve cleaned the old paste off the heatsink, but haven’t touched the cpu? Is this right?
Spec is below.
Thanks for helping
Case COOLERMASTER CM690 MKII ADVANCED CASE
Overclocked CPU OverClocked Intel® Core™i7 Quad Core Processor i7-950 (3.06GHz @ max 3.8GHz)
OC Settings Show/Hide
Motherboard ASUS® P6X58D-E: DDR3, USB 3.0, SATA 6.0GB/s, 3-Way SLI
Memory (RAM) 12GB KINGSTON HYPER-X TRI-DDR3 1600MHz, X.M.P (6 x 2GB KIT)
Graphics Card 1GB NVIDIA GEFORCE GTS450 - 2 DVI,HDMI,VGA - DirectX® 11, 3D Vision Ready
2nd Graphics Card NONE
3rd Graphics Card NONE
Memory - 1st Hard Disk 1TB WD CAVIAR BLACK WD1002FAEX, SATA 6 Gb/s, 64MB CACHE (7200rpm)
2nd Hard Disk 2TB WD CAVIAR GREEN WD20EARS, SATA 3 Gb/s, 64MB CACHE
RAID NONE
2nd DVD/BLU-RAY Drive NONE
Memory Card Reader INTERNAL 52 IN 1 CARD READER (XD, MS, CF, SD, etc) + 1 x USB 2.0 PORT
Power Supply CORSAIR 650W TX SERIES (TX650) 80+ ULTRA QUIET PSU (£76)
Processor Cooling TITAN FENRIR EVO EXTREME HEATPIPE CPU COOLER (£39)
Thermal Paste ARCTIC COOLING MX-3 HIGH THERMAL CONDUCTIVITY COMPOUND (£9)
Sound Card ONBOARD 8 CHANNEL (7.1) HIGH DEF AUDIO (AS STANDARD)
Spec is below.
Thanks for helping
RAID NONE
