Custom Pre-built Pre-order
D
Deleted member 17413
Guest
Its a nice M.2 drive, not the fastest, but M.2's are very very fast anyway and you arent going to notice much difference between them in general use, maybe save a second or two in heavy games when loading.
Its the OS that really draws the most from having a really fast drive, One of the corsair ones would make an excellent games drive, but I would doubt you would tell any real difference between that and the PCS own brand 1TB.
19dayne
All right thanks! I think I'm going to have 1TB SAMSUNG 970 EVO PLUS M.2, PCIe NVMe (up to 3500MB/R, 3300MB/W) one instead, seems really good
19dayne
Hey Guys, I'm planning on ordering a custom pre-built soon and i have a couple of questions;
  • I'm ordering the pc without an operating system and i was wondering how they would go about testing the pc if its not got windows?
  • I've put done RGB led strips with the build for £10 and was wondering if they themselves would put the led strips inside the build and i'd get the remote with it right?
  • would three LL120 fans would be good enough right? and i could always get more in the future
Thanks, Dayne
also here are the specs:
16GB Corsair VENGEANCE RGB PRO DDR4 3600MHz (2 x 8GB)
12GB NVIDIA GEFORCE RTX 3060 - HDMI, DP
CORSAIR 850W RM SERIES™ MODULAR 80 PLUS® GOLD, ULTRA QUIET
STANDARD AMD CPU COOLER
LED Lighting
50cm RGB LED Strip
Extra Case Fans
NO OPERATING SYSTEM REQUIRED
NO RECOVERY MEDIA REQUIRED
Price: £1,357.00 including VAT and Delivery
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/amd-am4-gen3-pc/krfa7!u3Qg/
AleTax
Thanks, Dayne
LED Lighting
50cm RGB LED Strip
Extra Case Fans
Hey man, the PC will be tested with a test version of Windows 10 (it's highly recommended to install your fresh copy once you receive it :))
For the LED strips, the easiest thing to do is to control them via your motherboard.
What are you going to use this PC for? What monitor will you be using (make / model or resolution / refresh rate)?
Could you also tell us your max budget? There are a couple of things that can be improved :)
19dayne
Hey @AleTax thanks for the reply!
I will get Windows 10 when i do receive i just didn't wanna pay around £80 extra when i can get it cheaper
The led strips makes sense thanks!
The PC will be used for gaming and uni work, i take a graphics design course but i do have a macbook for my uni work anyways
My monitor atm will not be good enough for pc but i will upgrade to a much better monitor when i get the money, and i don't want to lower any of the specs just because of my monitor, I'd rather get a new monitor later than upgrade the pc later.
i currently have a Asus with 75hz, 1080p :
My budget is below 1.4k and would prefer to stay below 1.36k> as i cant go any higher for the time being
Ash_
Master Poster
If you can stretch to this... this will be better than your current spec. Although you did a really good first attempt.
256GB PCS PCIe M.2 SSD (1900 MB/R, 1100 MB/W)
LED Lighting
50cm RGB LED Strip
Extra Case Fans
Price: £1,405.00 including VAT and Delivery
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/amd-am4-gen3-pc/b8WHAcq77S/
19dayne
LED Lighting
50cm RGB LED Strip
Extra Case Fans
I see, thanks for the help, but i think I'm going to stay with my current build as I can stretch it past 1.4k, i appreciate the help tho!
Ash_
Master Poster
The £50 extra to get the 5600X is a monumental difference. Drop the 256gb m.2 if needs be, but 5600X absolutely demolishes the 3600X by a significant amount.
19dayne
I see i see, but wont the m.2 SSD drive speed be a bit slow?
Ash_
Master Poster
The pcs drive is still extremely fast. The core parts of the build, when working out suitability are CPU and GPU. Sacrificing the CPU for a better SSD (which is a luxury) leaves you with a worse build and i would take a 5600X with a pcs drive, over a 3600X with a 970 absolutely every day of the week.
19dayne
thanks! I reckon i'll take ur advice, since i have a b550 motherboard i can always get another m.2 drive later on.
I'll also get rid of the LED strips -£10
so it'll be 1,377k total.
Ash_
Master Poster
Indeed, a second m.2 is extremely easy to install at a later date and occasionally they have incredible deals on them.
19dayne
I was thinking of going for a different m.2 sdd drive: 1TB INTEL® 670p M.2 NVMe PCIe SSD (up to 3500MB/sR | 2500MB/sW)
This is only £3 more expensive but has double the speed, should i go for this?
Ash_
Master Poster
The 2TB one is absolutely fantastic, but the 1TB has average write endurance, which is the point of failure, the 500gb is even worse. I would be very tempted to say go for it, as it is a gen 3 and by the time it does fail in many year, gen 4 will be cheap as chips.
The 500gb and 2TB are 660p though and i wouldn’t recommend those.
Bigfoot
Grand Master
Previous versions of Intel m.2 drives had really poor write endurance. The 670p seems to have improved, but is still not up to the Samsung drives. The Intel m.2 does have almost double the endurance of the Corsair MP400 drives that are more expensive and often being recommended here. I don’t know if there any published endurance figures for the PCS equivalent. I don’t know if you will see much difference in real life, but I can’t really see a major issue going with the 670p. I would not have said the same for the earlier Intel drives.
PS all write endurance figures were from Tom’s hardware reviews
19dayne
So, would you guys recommend going for the 1TB 670p or stick with the 1TB PCS PCIe m.2 ssd drive?
Ash_
Master Poster
I’d go intel personally. They have a 5 year warranty and unless you use really work your pc, i can’t see it failing any time soon and even once it does, they are not difficult or expensive to replace.
19dayne
I don’t have either of them myself. For £3 it is probably worth going for the Intel 670p
All right, Intel it is, thanks for all the help guys!
19dayne
Hey Guys, I was wondering what mobo i should go for between:
and
TUF gaming mobo being cheaper than the Strix, i was wondering which one i should go for and what the difference is?
Here are the specs of the build
ASUS® TUF GAMING B550-PLUS (DDR4, USB 3.2, 6Gb/s) OR ASUS® STRIX B550-F GAMING (DDR4, USB 3.2, 6Gb/s)
Extra Case Fans
