Custom Pre-built Pre-order
Citrus_9
Expert
If you do music/audio editing, go with B550-F. For any other cases go for B550-PLUS is a CPU isn't 8 cores or more (in that case X570 would be better).
What would be a PC for? What's a monitor and a budget? Best is to seek for advise on the whole build, not just separate components.
19dayne
I do not do music/audio editing.
PC is mainly for gaming and some light graphic designing
Currently i have a 1080p 75hz monitor but i will upgrade to a 144hz when i get the moneys
my budget is 1.4k> id rather not go any higher than i am already am at, which is £1,482.
Is there anything wrong with the previous recommendations?
19dayne
No, theres nothing wrong with the recommendations, its just i was wondering what the difference between the two mobos was since one was cheaper than the other, if its a lot more worth it going for the more expensive mobo than i'll get that one but i was just curious to see if i could cuz out a few ££
19dayne
i just saw that TUF gaming mobo only has 1 m.2 drive slots, so i'll stick with the Strix mobo, thanks guys!
Citrus_9
Expert
Oh snap, looks like im a dumbass, since theres two I may go with the tuff mobo. So only gen 3 m.2 are compatible with the TUF mobo?
The answer is Yes.
Gen 3 and Gen 4 means very little: they have same connection, it only describes the speeds. Meaning that you can run Gen 3 M.2 SSD in a Gen 4 M.2 slot but you still get only speeds as per the M.2 storage. But if you buy two Gen 4 super fast M.2, one of then will work slower because there's only one Gen 4 slot, meaning the other M.2 (in the Gen 3 slot) would be limited speed as per Gen 3 slot capabilities.
OHH, Sorry for my dumbass haha, thanks guys. Other than m.2 drives, what other MAJOR differences are there between the two? should i just go with the TUF mobo to cut the price?
It's the VRM's that are more important than anything, the Strix has a far better VRM setup which is important with Ryzen 5000.
If it were me on any B550 I wouldn't go lower than the strix. But with the 5600x, it's not really so important.
Your choice.
19dayne
Your choice.
Thanks for the help! I think i'll go for the Strix Mobo
19dayne
Hey Guys, I'm going to order a custom pre-built within the next few days and these are my final specs:
Note;
  • My current monitor is a 1080p 75hz, which i will eventually upgrade to a 144hz monitor when i get more money.
  • The PC will be used mainly for gaming and some light graphic designing.
16GB Corsair VENGEANCE RGB PRO DDR4 3600MHz (2 x 8GB)
12GB NVIDIA GEFORCE RTX 3060 - HDMI, DP
CORSAIR 850W RM SERIES™ MODULAR 80 PLUS® GOLD, ULTRA QUIET
STANDARD AMD CPU COOLER
Extra Case Fans
NO OPERATING SYSTEM REQUIRED
NO RECOVERY MEDIA REQUIRED
Price: £1,382.00 including VAT and Delivery
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/amd-am4-gen3-pc/Cg!JHz4PwE/
Citrus_9
Expert
Note;
Extra Case Fans
The first questions I'd be interesting to know is when you'd be upgrading a monitor to 1440p? If within a year, I'd pick a 1440p GPU straight away as there's no point in paying twice.
What particular software you'd be using for a light graphic design?
And the most important to the end :) What's your budget without a monitor? Ideally best is to get a PC for 1440p and a 1440p monitor together right now.
19dayne
I'll most likely get a new monitor by the end of this year.
Softwares such as Photoshop and Illustrator, though i am not too bother about them as i have a macbook pro 16 to do all the graphic designing on
My Monitor budget will be around £150, below £200 though. I can't get a new monitor and the PC together as I only have a budget of 1.4k and id have £18 spare after this PC purchase, so i'd rather get a good pc now and upgrade monitor later on.
19dayne
Lads, I've noticed the price of my custom pre-built price going up in the past 2 days, its gone up by £10 overall. do i order it now? or wait for the price to go back down?
Prices are going to fluctuate a lot at the minute. If you save your quote it keeps the price locked for 5 days I believe
