Desktop Build Advice
Mick81
Hello, I was hoping someone could help answer my question on graphic cards. I’m building a pc on pcs website and looking at the RTX 4070ti or the 4080. I’ve noticed it doesn’t specify which brand these cards are and was hoping someone may know which brand pcs tend to use and whether they are a good brand?
Thanks in advance
Mick81
Hello, could I please ask for people opinions on this build I am looking to order. The main purpose of this build will be for gaming. My monitor will with be the Samsung Odysessy G7 27” or the Dell S2722DGM. I was wondering about the graphics card. The one shown will be a Palit or Zotac. Is it worth me getting the build without a card and buying my own RTX 4070ti ASUS Strix OC or will I not really notice the difference. Any advice is welcome, thanks.
Hiya, if you could post the full specs please so we can edit it? You can't do anything with images
What's your max budget?
I take it you mean the 1440p Samsung G7?
Full specs are
CPU - Ryzen 7 7800X3D
Board - Gigabyte x670 Aorus Elite AX
RAM - 32gb Corsair Vengeance DDR5 6000mhz
G Card - 12gb RTX 4070ti
SSD - 512gb M.2 for the windows OS
SSD - 2TB storage
Power supply - Corsair 850w RMx series modular 80
Processor cooling - Corsair H100 RGB elite performance
In terms of budget, I didn’t want to spend more than £2500 and this build is currently at £2240.
If you can post them as in the guide above, gives precise instructions, just copy and paste.
Or are you not seeing the link?
Mick81
LIAN LI LANCOOL 205 MESH C GAMING CASE
GIGABYTE X670 AORUS ELITE AX (AM5, DDR5, PCIe 4.0, Wi-Fi 6E)
12GB NVIDIA GEFORCE RTX 4070 Ti - HDMI, DP, LHR
512GB PCS PCIe M.2 SSD (3500 MB/R, 3100 MB/W)
2TB PCS PCIe M.2 SSD (3500 MB/R, 3100 MB/W)
CORSAIR H100x RGB ELITE HIGH PERFORMANCE CPU COOLER
ONBOARD 2.5Gbe LAN PORT
2 PORT (1 x TYPE A, 1 x TYPE C) USB 3.1 PCI-E CARD + STANDARD USB PORTS
Price: £2,238.00 including VAT and Delivery
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/amd-am5-pc/BGvyXkSCEG/
Just reconfigured a little, the PSU was too low to support upgrades beyond where you were, the case was too low tier for the components, the drives were very budget, changed the board for Asus, will link why below, other than that it's fine
ASUS® TUF GAMING X670E-PLUS WIFI (AM5, DDR5, PCIe 5.0, Wi-Fi 6E)
1TB SOLIDIGM P44 PRO GEN 4 M.2 NVMe PCIe SSD (up to 7000MB/sR, 6500MB/sW)
2TB CORSAIR CORE XT MP600 NVMe PCIe M.2 SSD (up to 5000 MB/R, 4400 MB/W)
CORSAIR 1200W RMx SHIFT SERIES™ MODULAR 80 PLUS GOLD, ULTRA QUIET
Microsoft® Edge
Price: £2,462.00 including VAT and Delivery
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/amd-am5-pc/6Mw02t7aM5/
Gigabyte motherboards have had some very very shady dealings with this generation, and IMHO are worth avoiding, but also, they double up beep codes and generally have other bugs that can make troubleshooting extremely challenging.
With regards to GPU, people get very confused.
A GPU is actually simply the chip on the card that looks like this, the blue square part:
A graphics card is the board design and power relays and cooling shroud.
All GPU's are the same, no matter what brand or model you buy, so it doesn't matter if it's an Asus OC, or a Palit non overclock, they're all using the same nVidia 4070ti chip (and AMD cards all use AMD chips)
These days, because of the way chip design has become, there's almost no benefit in an overclocked card, as modern GPU's automatically overclock themselves as standard.
For very niche uses like render farms or heavy calculations on scientific workflows that go on solidly for days on end, there would be an argument for a premium graphics card as the improved cooling could come in beneficial for those high stress applications.
But for gaming, it literally makes no difference.
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/amd-am5-pc/kZcmRSvHQp/
@SpyderTracks , you leaving Norton in😉
